Am I wiring my door locks correctly?
Old Jun 18, 2009 | 09:20 AM
w211 ryda's Avatar
Default Am I wiring my door locks correctly?
Was wondering if anyone could verify if this is the correct way of wiring a Python 700 alarm to my door lock/unlock on my DB7. I’m so used to the 2 wires on the older DEI alarms, but this one on my new alarm is confusing. I’ve attached 2 PDF files from the installation manual for reference.
This is how I’m planning to wire it up. Am I correct?
H3/A wire this to ground
H3/C tap into my lock wire
H3/F tap into my unlock wire
And I don’t need to touch H3/B, H3/D, H3/E, or H3/G?
One more question. In the Harness #3 PDF file, it describes the “H3/A as determining the output polarity of the H1/4”. From my understanding, doesn’t the H1/4 tap into the 12V ignition? Shouldn’t they be independent from each other?
File Type: pdf
File Type: pdf
Old Jun 18, 2009 | 09:51 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Am I wiring my door locks correctly?
The purple wire with the fuse goes to ground. And the green and blue are now your neg output unlock and lock triggers. You can find your lock and unlock wires in a grey plug behind the crusie control box. Blk with red stripe and black with white stripe.
Old Jun 18, 2009 | 05:25 PM
w211 ryda's Avatar
Thanks Killer!! Made my installation that much easier! I might hit you up on another wire in case I can't figure it out.
Old Jun 19, 2009 | 07:18 PM
anytime.
low_crx87
Audio / Security / Video
Oct 8, 2005 12:58 PM
blackEyEdpEas
Jun 3, 2004 06:13 PM
intezn
Sep 3, 2003 06:39 PM
oeklm
18
Feb 21, 2003 02:48 PM
DocYahoo
15
Jul 20, 2002 04:29 PM
