Sorry for another traction bar question...
Old Jun 17, 2009 | 02:39 PM
7rrivera7's Avatar
Default Sorry for another traction bar question...
Need to decide between the Spoolin Performance EG Bar:
http://www.spoolinperformance.com/sp...49cfdc55f7d302
...and the Full Race EG Bar
http://www.full-race.com/catalog/pro...7ca00d475f8cd9
Difference is $150 - is it worth it or are both designs similar enough to go with the SP bar?
Old Jun 17, 2009 | 02:45 PM
DonF's Avatar
Default Re: Sorry for another traction bar question...
What do they say in the.the SUSP. forum? I know I ask about ign. timing in that forum all the time.
Old Jun 17, 2009 | 02:47 PM
killerpenguin21's Avatar
those two bars are very similar designs, and will most likely be about equal in performance.
the important part is both of them use the proper geometry to prevent suspension binding.
i have the full race, because i got it during their end of year/xmas sale.
Old Jun 17, 2009 | 02:51 PM
edwardsullivan6's Avatar
i heard the us military is gonna start using civic hatchbacks...
Old Jun 17, 2009 | 03:41 PM
7rrivera7's Avatar
You are right Don - sorry I mistakenly posted in 'your' forum.
Old Jun 17, 2009 | 03:43 PM
7rrivera7's Avatar
Thank you sir - this is the kind of information I am looking for ;-)
Old Jun 19, 2009 | 02:49 AM
7rrivera7's Avatar
34 views in the suspension forum and not one reply. Maybe I should post about my ignition timing problem...
Old Jun 19, 2009 | 02:08 PM
DonF's Avatar
Sorry about that, but that is where I ask Suspension questions. I also ask Drag questions in the Drag forum, and RR questions in the RR forum.What do I know? 5 degrees castor, -.5 camber (drag) Left front spring + 50 lbs. ( depending on ride height) I like droop limeters in the front and a very high rear wheel rate. 16 degrees, initial, and WOT depends on fuel properties and dynamic comression. I would keep the camber curve to less than .5 degrees per inch of travel. I would also de-bump the front steering to less than .012 of an inch, in the operating range you are using. Not sure what that is going to be.
Old Jun 19, 2009 | 10:58 PM
maybol1j's Avatar
^waaaaaaaaaa^
Old Jun 20, 2009 | 10:45 PM
95skunkedgsr's Avatar
this is why u dont ask tech ppl for tech answer's ... they will give u a answer that will blow your mind
7rrivera7
Jun 19, 2009 05:46 AM
7rrivera7
Suspension & Brakes
Jun 19, 2009 02:46 AM
srmofo
Welding / Fabrication
Mar 13, 2009 05:25 PM
Myh4tch
Jan 16, 2004 10:54 AM
Myh4tch
Jan 16, 2004 06:40 AM
