Do i still have some more potential?
Old Aug 20, 2002 | 07:49 PM
StinkyTofu's Avatar
Default Do i still have some more potential?
Currently my set up is making 180 whp.
Do you guys think i could make a decent amount of more power if i got a skunk2 manifold, obd 1 ecu + hondata, and then had it retuned?
[Modified by StinkyTofu, 9:35 AM 3/15/2003]
Old Aug 20, 2002 | 07:51 PM
Malice's Avatar
New User
Default Re: Do i still have some more potential? (StinkyTofu)
p&p the head dood. get the rest of that stuff and u'll be over 200 with tuning easily
Old Aug 20, 2002 | 10:29 PM
StinkyTofu's Avatar
Default Re: Do i still have some more potential? (MaliceGSR)
Could i make it safely into the 190s without P&Ping my head?
Old Aug 20, 2002 | 10:59 PM
MK Ultra's Avatar
Hondata would be a great addition.
Personally I don't like the S2 IM for the B18C1 head because the port angles do not match up.
With a Hondata GS-R ECU you could tune the IAB switchover. That probably won't help your peak numbers, but with the fat primary lobes of the Toda Bs you should see a nice midrange gain by setting the IAB switch a bit lower.
Old Aug 21, 2002 | 02:32 AM
PYITR821's Avatar
My brother has the Skunk2 IM on his 99 Gsr and it made a big difference, definately worth the money. I hear Kenji sells chipped P28's which also make pretty good horsepower. Get the Skunk2 IM, AEM CAI for a Type R and Kenji's P28 and you will definately be making some power you can feel.
Old Aug 21, 2002 | 12:02 PM
1.8 Hybrid's Avatar
Just installed sk2 manifold on my car and it was a world of difference, you will see a huge difference w/ cams, manifold, and a chipped single stage runner ecu...
Old Aug 21, 2002 | 12:25 PM
rodrez.'s Avatar
quote
GSR motor with Toda Spec B, 11.6:01 compression, i/h/e, vafc, fpr, and cam gear tuning.
I have a similar set up, w/CTR cams and lower compression, also using the Skunk2 mani, and I hit 180 at the wheels also, so I'm sure there's potential to mak much more power there. If you put the manifold on, consider having it cleaned up, as stated earlier, the ports don't match perfect, and it's very rough throughout, made a world of difference in the midrange as well as the top end on my car. (look for a throttle body also)
Old Aug 21, 2002 | 02:07 PM
StinkyTofu's Avatar
Default Re: Do i still have some more potential? (rodrez)
Will i lose alot of midrange if i switch to the skunk2 manifold? Or could that be made up with hondata tuning?
Old Aug 21, 2002 | 04:19 PM
Isaac's Avatar
New User
I've heard positive things (better than Skunk2) about the JD Edelbrock Victor X Manifold...if you can them. Either way, it will definitely help out your car...
Old Aug 21, 2002 | 04:31 PM
stick's Avatar
what type of header and exhaust do u have?
Old Aug 21, 2002 | 04:56 PM
simple4012's Avatar
New User
Default Re: Do i still have some more potential? (stick)
the JG manifold fits like **** for a street car. Hits the heater ****. Id stick with what you have man. You might want to look into a standalone ecu system or hondata.
Tom.
[Modified by simple4012, 1:56 AM 8/22/2002]
Old Aug 21, 2002 | 06:59 PM
StinkyTofu's Avatar
Right now i have the JDM 4-1 and apexi n1 cat-back.
eg8allmotor
Jun 17, 2007 09:25 AM
thegreat0ne
Apr 17, 2007 09:18 AM
95SolSi
Oct 11, 2004 05:19 PM
96redgsr
Feb 1, 2004 02:32 PM
fukaintmuven
Nov 7, 2002 12:02 AM
