H2B DYNO THREAD!!
I wanna see what numbers are being layed down with h2b swaps also specify the car weight, and if you have any track times. J.w if its really worth doing which im sure it is
I'm on my third h2b setup. Heres some numbers.
1ST SETUP
-QSD KIT
-STOCK H22A4 WITH BOLT ONS
-ITR TRANS 4.78 FD
-UNTUNED
-STOCK SUSPENSION IN A EG HATCH
13.40 AT 105MPH HITTING LIMITER IN 4TH GEAR (22 INCH SLICKS)
2ND SETUP
-EVO KIT
-H22A ENGINE WITH CROWER 2'S WITH SAME BOLT ONS
-ITR TRANS 4.78 FD
-TUNED 240WHP ON PUMP 93 OCTANE
12.51 AT 109.72 MPH AGAIN HITTING LIMITER IN 4TH GEAR (22 INCH SLICKS)
3RD
-EVO KIT
-H22A ENGINE WITH CROWER 3'S WITH SAME BOLT ONS
-ITR TRANS 4.78 FD
NOT TUNED YET AND UNSURE OF TRACK TIMES YET
THIS TIME IN A EG COUPE, GUTTED, OMNI DRAG SUSPENSION AND GOING TO TRY
24.5'S FIRST THEN TRY 23'S.
ALSO, SOME DRIVER ERROR WHICH I DONT HAVE A PROBLEM ADMITTING TOO.
NOTE: STOCK BOTTOM END AND UNPORTED HEAD.
1ST SETUP
-QSD KIT
-ITR TRANS 4.78 FD
-UNTUNED
2ND SETUP
-EVO KIT
-ITR TRANS 4.78 FD
3RD
-EVO KIT
-ITR TRANS 4.78 FD
well my builds comng in soon no numbers yet just a simple set up. heres what it consists of.
-jdm h22a
-qsd kit
-rmf replica header (open header)
-v stack
-ported stock mani with 65 mm tb
-balance shaft removes
-manual tensioner conversion
-b16 tranny
-carbon syncros
-obx lsd
i'd be happy if i make anything over 210. is this possible with my set up???
-jdm h22a
-qsd kit
-v stack
-b16 tranny
-carbon syncros
-obx lsd
JDM H22 stock longblock.
QSD H2B kit
Stock cable B16 trans
megan header
untuned.
Chipped p28
street driven Crx full interior (DX)
on 22" slicks
12.3 Eta
JDM H22
sleeved block
QSD H2B kit
Stock H22 crank
Skunk 2 pro 1 cams
megan header
Crome tuned p28
on 24.5" slicks
11.7 Eta
QSD H2B kit
megan header
untuned.
Chipped p28
on 22" slicks
12.3 Eta
JDM H22
sleeved block
QSD H2B kit
Stock H22 crank
Skunk 2 pro 1 cams
megan header
Crome tuned p28
on 24.5" slicks
11.7 Eta
heres one for ya
car weighs 2040 lbs. w/ driver and has been 11.06 @ 125.4 mph and will go 10.8x or probably quicker by the end of the season.
build specs are very simple other than a custom intake manifold.
definately a mild build and yes very worth it to go h2b
you can make plenty of power and its very cost effective
heres another example:
this was a stock h22a using stock exhaust manifold and a comparison between stock, skunk2, and euro r intake manifolds. car went 12.0x on that stock setup
added some pro 1s and it broke 11.8x still w/ a stock bottom end and stock exhaust manifold
both set ups are f-ing nice and very impressive. hopefully someday i can say the same.
heres one for ya
Thank you, all my hardwork is finally paying off and im sure the same will come for you over time.
as far as the H cable trans not shifting..... i have more than my share of experience w/ this matter also haha
as long as the trans is in good internal condition and the cables are in good condition it will shift, however it still wont shift like a B series
the most important upgrade on an H trans is a twin disk clutch. you will have no worries after installing a twin
as for performance gain w/ H2B, you WILL make more power to the wheels, not sure if this is due to the gearing or drivetrain resistance, imo its a combination of both.
you will run quicker w/ the B trans and drop up to .5 from your 1/4 mile et.
I'm glad somebody finally verified this. Being saying the same thing for a long time. B/c i never seen a stock h22 make 220 all stock. On a good day between 190 - 200whp. Looks to be a 20 to 30 whp increase depending on if ur motor has good compression and good tune.
very tru ..
