SRS removal
Old Jun 17, 2009 | 04:54 AM
lsjon's Avatar
Default SRS removal
Looking to change out my steering wheel and eliminate the air bags, so in return might as well remove the srs wiring. My question is does the srs signal light still run through the pcm(ecu), or will removing the controlunit/srswire/and airbags eliminate the light from coming on. And if not what steps will be needed for this. Thanks
Old Jun 17, 2009 | 08:09 AM
92civlude's Avatar
Default Re: SRS removal
There is a SRS indicator control inside the cluster assy. If you unplug the SRS ,the light will still turn on. Might as well remove the bulb.
Old Jun 17, 2009 | 12:23 PM
lsjon's Avatar
Thankyou. Wasn't sure if their was a signal through the cluster or the pcm.
Old Jun 17, 2009 | 02:11 PM
Hawkze_2.3's Avatar
Yep, just pull all that stuff out (SRS wires are all covered in yellow) and remove the SRS bulb from the cluster.
Civic-Kids
Oct 2, 2009 03:08 PM
Slava.
10
Apr 29, 2006 07:33 PM
CW-ITR
Aug 28, 2005 03:47 AM
C-speed
Sep 6, 2001 08:07 PM
