b16a
Old Aug 20, 2002 | 07:18 PM
stangkilla's Avatar
Default b16a
hey i have a 95 civic dx i was going to swap a b16a in there i know i have to have axles shift linkage tranny stuff like that i know i need the wiring harness to but heres what i am wondering you need an ecu what ecu do i need and how do you wire that harness because were my harness plugs to the fire wall the ends are different than the ones on the b16a so do i have to cut and re wire or what i would love some help thanks
Old Aug 20, 2002 | 07:31 PM
granada_sun's Avatar
Default Re: b16a (stangkilla)
youll need obd-1 ecu so p30 (del sol vtec). As for wiring, if motor is jdm chances are the harness is from a right-hand car, you can use either del sol vtec, del sol si, civic si (with si's you will need to add knock sensor wire), or gsr wiring harness.
93delslow315
May 20, 2011 11:34 AM
DelSolid21
Sep 29, 2010 11:12 PM
digital sol
Jun 29, 2006 12:32 PM
mongoliandonuts
Sep 8, 2004 09:15 PM
nomotorsol
Jun 18, 2004 09:19 AM
