led tail lights i need help
has anyone ever installed these lights if so can you explain how to install them please i thought they;d be plug in play but there not some help me asap thanks
oh sorry i own a 98 civic sedan
http://www.kingsource.com/alt-yd-hc96-4d-led-rs.html
Peel back your carpet in your trunk on the far side lights (i believe the centers are open access), look for the 4 nuts that lock the housing into place. Remove them and you should be able to fit the new ones in.
Post the symptoms if its a blinker/lighting issue.
the problem im having is the lights itself have an onboard led board and the harness it comes with doesnt stright plug in to the factory one im trying to do it where i dont have to cut and make it work
There may be no way to avoid it :/ What I would do is just cut back enough to leave a decent pigtail on the connector.
Treshon Kekoa
Feb 14, 2019 11:34 PM
