trap mph what do you think
Old Jun 16, 2009 | 07:44 PM
maybol1j's Avatar
Default trap mph what do you think
Well I chanch to take the hatch to the drag strip and this is what she produced.
14.0 1/4
2.6 60ft
101 mph
This is on falkin azenis spining all the way to third.
Im not sure how much my hatch weighs but its pretty gutted.
B20v
Mild port+polish by me
Sk2p2 cams
11.5.1.comp pistons
Typer r header 4.1
240cc injectors
Untuned.
Feuture plans tune tune tune 23 inch slicks and bigger injectors.my ? Is are those trap mph closer to a low 13 high 12?
Old Jun 16, 2009 | 08:06 PM
kangaroo's Avatar
Default Re: trap mph what do you think
I think you need some slicks...
2.6 60ft is horrible.
Old Jun 16, 2009 | 09:12 PM
fiero87's Avatar
that trap is on par for the time you ran. however you should be faster i would believe. but to really tell what car is it, what tranny, why the **** are you spinning through third. and the 60ft is shitty. so learning to drive alittle better would be a place to start and that takes practice so get out there to the track more ofter, dont dump the clutch and stab the gas and dont power shift full knowing it leads to you spinning the tires off.
for reference my hatch with 186whp weighing in at about 2300 with me in it went 13.5 @ 103.5 with shitty kumo tires and a 2.08 60ft
Old Jun 17, 2009 | 01:22 AM
maybol1j's Avatar
I got it down to a 2.4 that same day but that still sux.considering the tires I was using can't expect to much.
Old Jun 17, 2009 | 01:54 AM
95DC2GS-R's Avatar
Your trap speed is pretty good, you just need to work on your launch.
Don't dump the clutch.. let it slip just a little bit to get you out of the hole. With a good launch and a set of decent tires/drag radials, you should be in the mid/high 13's.
I was running shitty times, like high 15's, but my trap speed was there. I got a decent radials, preloaded and launched at around 3200rpm and pulled off a 2.03 60' with a 14.4..
I just got better mounts, as well as traction bars so I should see even a better launch.
Old Jun 17, 2009 | 06:06 AM
kangaroo's Avatar
With a 101mph trap speed you could run low 13's on slicks.
I was running 13.6 at 99mph.
My buddy was running 13.4 at 100mph.
Old Jun 17, 2009 | 03:04 PM
maybol1j's Avatar
yea i def need some slicks in my life,and a good tune maybe be able to break 12 on the motor
Old Jun 17, 2009 | 03:15 PM
NirVTEC's Avatar
Dragging untuned cars FTL!...
Old Jun 17, 2009 | 08:11 PM
Dark_Teg's Avatar
What was your 1/8th mile time and mph? Last Friday I went 77.6mph in the 1/8th with a stock B18CR in a CRX @3000ft.
boostjunkie757
Mar 21, 2014 05:04 AM
.Hatches.
Oct 3, 2008 10:36 AM
Captn. Save A Hoe
Oct 27, 2003 12:50 AM
Casey
Aug 4, 2003 09:15 AM
gigantor
May 24, 2002 11:54 AM
