obdII motor in obdI car - wiring details?
Old Aug 20, 2002 | 06:45 PM
hondamaticdragbike's Avatar
Default obdII motor in obdI car - wiring details?
repinning distributor. Can someone specify what color goes where? Putting a '99 CX motor in a '94 CX hatchback without wiring diagrams/manuals.
Old Aug 20, 2002 | 06:50 PM
R_yd's Avatar
Default Re: obdII motor in obdI car - wiring details? (hondamaticdragbike)
get a manual
Old Aug 20, 2002 | 08:21 PM
CanuckCRX's Avatar
New User
Use the OBD1 engine harness, and the only wires you will have to change is the alternator (Cut the OBD1 alt. plug off and use the OBD2), distributor (cut and match colors) and use the OBD2 injectors and injector plugs.
Lastly, obviously use your same OBD1 ECU.
And a manual would definately help you, because some of the wire colors on the alternator are different between OBD1 and OBD2...black/yellow matches up, I think blue goes to white/red, and white/blue goes to white/blue...just did one but don't remember..
If you need more help just email me at thespeedofsound@yahoo.com
Glad to be of assistance
Jay
LD_EGSICK
Apr 19, 2007 06:30 PM
lsvtechatch92
Mar 7, 2007 06:44 PM
CunninLynguist
Oct 12, 2006 05:35 PM
mister2racer
Oct 14, 2004 07:33 PM
ANGELL
May 24, 2003 03:18 PM
