Various brake pictures... (lots of pics)
Is the legend caliper the same/similar to the NSX caliper, without the logo and cooling fins?
Will
-who would
himself some NSX calipers.
i'm still confused, why 23mm instead of 28mm rotors?
28mm = may fit... may cost more... may work better...
Will
-who sticks with what works.
23mm = $24.95 each...
Will
Will
when you say may fit...i thought stock legend gs rotor were 28mm...so why the may fit statement...very confused...i'm picking up a set next week thats why...
The Legend rotors I buy are 23mm thick and are for LE/SE models.
https://honda-tech.com/zerothread?id=181691
Willard, Ive always wondered, if you swap the calipers from side to side, wont the pistons be in the wrong side of braking?
yes. but according to some the difference is not noticeable.
Jason-
who just exchanged for two new sets of rotors, under warranty of course
I've tried different rotors on my car. Under the same amount of track usage, the Brembo ones lasted me almost 3 times longer then some generic brand rotors before showing heat cracks. When you buy rotors, try to find out where the rotors were made in. If they were made in China or Taiwan, they are dirt cheap but crack so much easier for track use (ie. Autozone rotors). Granted my car is quite a bit heavier than a type R so it's not a direct comparison. Just want to get the point across.
Its a cost issue.
While he may buy one set of AutoZone rotors, you will buy many brembos.
Warranty is a wonderful thing...
OR as some might say...warranties OWNz j00!
aet
aet
Will
-who loves what he pays for.
Arent brakes fun
I didnt know ITRs had 2 piston floating calipers. Good to know!
What kind of pads are you using?
And why are those rotors red? I bet the brake dust colors your wheels nicely!
great picutres, Could you explain which peices you heat wrapped, so I could follow
also for those who have nothing better to do then complain, GET A JOB or go back to work
My Aimco rotors (ie. Autozone) were made in the USA...
And from those pictures, you DO need some new rotors!!
stock is one piston floating.
https://honda-tech.com/zerothread?id=243696
I thought only those rotors made in the far east could be sold for so cheap.
nope..
I plan a 3-day event at VIR and a 2 day event at Lowes before I retire those bad boyz. (this and next weekend
)Will
-tight wad
great picutres, Could you explain which peices you heat wrapped, so I could followlower ball joint, steering ball joint and ABS sensor + line.
