Anybody have suggestions for Strut bars for 94 teggy??
WTF? Do we look like your own personal concierge? Do you want us to give you a map and directions to each shop, too?
That being said, strut bars are all basically the same. Some would argue that those with fixed end (i.e. welded) are more stiffer - which is probably true. However, I would doubt that it would make a significant difference anyways.
If you want an inexpensive strut bar, say for under $20 bucks - check out Ebay.
If you wants something under $75 - check out Megan Racing. www.meganracing.com
Over $100, check out NRG www.getnrg.com
Or if you just want bling, Mugen.
Stock front one is fine, or OEM ITR or replica (exact same) if you want something a bit nicer. I have a cheapo rear bar that was given to me, mainly to secure my sub box
i got a itr strut bar from a friend's type r and im about to buy a type r upper rear strut soon just saving money. if you want a real strut bar though try going for the password jdm ones they have a combo sale for front and rear
JDMPassword seems to have constructed a good piece. IMO, strut bars are kinda a show thing. Yeah, they help with tower flex, but you think that single nut that hold the bar to the support brakets is gonna hold you throwing your car around corners? Are you using for track? If not, don't waste your money.IMO. As for JDMPW, they don't have that nut to hold the bar to the support,.Its all welded solid. I don't have a strut bar, and I probably won't need one. BTW, it will look with that APC intake.J/K all IMO.
Here is a list, some of these are not cheap.
Carbing 3pt
Rigid 3pt
PasswordJDM 3pt
Benen 3pt
Integra don't have Struts. So why are these called Strut Tower bars?
Carbing 3pt
Rigid 3pt
PasswordJDM 3pt
Benen 3pt
the op was asking for strut bars and how much they cost. all 2kracing jm did was post a link to some options.
anybody got a DIY on Type R front Strut bar install??
Tried searching but can't find any.
If anything, Just want the size of bolts and best way to anchor them.
EDIT: (found it 12mm nut with 8mm bolt + JB weld to secure them)
thanks!
thanks!
I would save that money and use it for other mods first. you will get far better results with a nice sway bar. Its definitely a little more money then a strut bar, but the performance gains are far more significant.
