ground control top hats
Old Jun 15, 2009 | 11:33 PM
on-site ej1's Avatar
Icon6 ground control top hats
noob questioin... do ground control top hats drop your car even though you have stock springs??
Old Jun 16, 2009 | 07:46 AM
danomatic93's Avatar
Default Re: ground control top hats
nope, the springs are what do the lowering. When you lower a car 3 inches or so, you may want to consider GC top hats as they allow the shock to sit closer to normal.
Old Jun 16, 2009 | 07:57 AM
Marauder's Avatar
The GC top hat only extends the shock rod to keep it from bottoming out. When you lower a car, the valve assembly that controls the flow of fluid moves closer to the bottom of the shock body. The GC top hat extends the rod and allows for a lower car to place that valve more in the middle of the shock body to allow for proper shock damping.
The GC top hats do not do anything to lower a car, you need either lowering springs or a GC coilover setup to change the ride height.
Old Jun 16, 2009 | 08:24 AM
melvinbrian's Avatar
NOPE!!!
Old Jun 16, 2009 | 08:28 AM
98civdx's Avatar
Master Detailer
no
Old Jun 17, 2009 | 09:55 AM
kool thanks
daniel_yu
Suspension & Brakes
Jun 12, 2008 05:58 PM
BIG T
Suspension & Brakes
Dec 31, 2007 08:29 PM
numotive
Feb 28, 2007 01:51 PM
TurboLaxx
Suspension & Brakes
Jan 2, 2006 08:21 PM
John O
10
Nov 6, 2003 06:53 PM
