#2 cylinder exhaust valve keeps breaking
Old Jun 15, 2009 | 03:17 PM
CSLAVE's Avatar
New User
Default #2 cylinder exhaust valve keeps breaking
Hi on my dads 91 accord an exhaust valve keeps breaking in the #2 cylinder. Its broke twice, took a chunk out of it. the first time we replaced all the valves, spark plugs, wires, and added a MSD.
Once replace it has a problem of not wanting to accelerate till a certain RPM. Once above that RPM it runs fine. Well that magic RPM kept getting higher and higher till the valve broke again. We pulled the head and all the valves looked fine except the two exhaust valves on the #2 cylinder. One had the same problem as before.
So we replaced the two valves and now replaced the fuel injector in the cylinder. Didn't fix the RPM issue. We don't know what else it could be besides the ECU and we pulled that and there seems to be no issues with the board or caps. Before we pick and ECU up for a junkyard i came here to see if anyone has any opinions.
Any and all help will be appreciated. If anything is not clear ill elaborate.
PS. I posted here cause i figured who posts in the section should know their **** lol
Old Jun 16, 2009 | 09:23 PM
CSLAVE's Avatar
New User
Default Re: #2 cylinder exhaust valve keeps breaking
bump... any ideas would be helpful.
Old Jun 17, 2009 | 12:07 AM
NAcoupeNA's Avatar
valve spring could be worn, allowing the rocker arm to "slap" the retainer. that's my guess. wrong section too...
Eowyn1963
Honda CR-V & Element
May 21, 2014 02:42 PM
CSLAVE
Jun 17, 2009 03:20 PM
B18Sleeper
Dec 31, 2007 03:29 AM
whatVTEC
Jun 26, 2005 08:33 PM
Type R 702
Jun 23, 2001 10:25 AM
