02 sensor question!!
Old Jun 15, 2009 | 02:09 PM
silver98hx's Avatar
Default 02 sensor question!!
I have a 1998 civic hx with a 1.6 vtec that has a bad oxygen sensor up stream. when i checked my local part stores to by a new one they said that it was going to cost me $375.00 because it is a five wire Oxygen sensor. is there low cost fix or is there any way that i can rewire it so that i can use one of the four wire oxygen Sensors.
Old Jun 15, 2009 | 02:33 PM
thesmogman's Avatar
Default Re: 02 sensor question!!
Our Honda's have some problems with cracked exhaust manifolds. This might be your problem. Pull the heat shield and inspect before dumping $375 for a new O2 sensor.
Old Jun 15, 2009 | 02:44 PM
sicones's Avatar
There is no way around it, you need to use the 5 wire wideband O2 on that car. Make sure it's really bad first.
Old Jun 16, 2009 | 10:32 AM
silver98hx's Avatar
okay i will do that. Thanks for the advice guys
bmheck5184
Jul 29, 2005 05:20 AM
BLUE EH3
May 16, 2005 07:24 PM
LsTurbo91
Oct 8, 2001 09:20 PM
G2_Integ
Sep 5, 2001 10:44 AM
