SEARCH!!!
Old May 26, 2009 | 07:02 AM
Stinkycheezmonky's Avatar
Suspetise...
Default SEARCH!!!
*********Search!!!******** This is the most important 'rule' in this forum. Use the search function first, before you ask questions. Reply in an existing thread rather than posting a new one. There is a ton of information here, and its either likely been covered before or will give you a head start. Redundant posts on frequent topics will be locked.
With the new Vb format, the method of searching has changed a bit. Here's a brief tutorial to return the best results:
**Start the CORRECT search by selecting "Advanced Search" from the Search drop-down menu**
1. Type in a generic search term, like "suspension." If you type in "suspension 1995 EJ9 coilovers" you'll return squat.
2. Select "Search Titles Only" to limit the results. Otherwise, you'll get 76% of all the threads ever made in the RR/AX forum.
3. In the lower right "Search in Forum(s)" box, select "Road Racing/Autocross" to further limit the results to the type of topic you're looking for.
Alternatively, if you are more informed on the subject you're trying to find, you can use more specific search terms, such as "koni shocks" or "225/45-15" or whatever.
When using combinations of words, try to list them in the order they'd appear in a thread or title, and enclose them in quotation marks the way that you would when searching Google.
As a last resort, you can use Google to search Honda-Tech by using the site: command on Google.
If you're lazy and say, "I know this has been covered, but I'm lazy and don't want to search for XXX" I'll lock your topic. I will then send to your home a midget named Frank, who will proceed to shave off your eyebrows.
Stinkycheezmonky
May 26, 2009 07:02 AM
flangemastermike
Apr 10, 2009 06:46 AM
teefunk01
Feb 26, 2009 10:02 AM
shyboi4u
Nov 14, 2005 09:53 AM
4drTEG
Oct 8, 2002 03:18 PM
