should i use this spraygun!?1st timer!
Old Jun 15, 2009 | 11:07 AM
HI91EFHB's Avatar
Default should i use this spraygun!?1st timer!
am planning on painting my car...
is this a good gun for the price to start off with?
http://www.homedepot.com/webapp/wcs/...ctId=100662098
can i have some advice if so?thanks
and what else do i need to get a good sand, a good prime,and a good finishing product?just asking...
thanks in advance.
sorry if this is in the wrong section..
Old Jun 15, 2009 | 11:12 AM
ALLxMOTOR EG's Avatar
Vietnamese!
Default Re: should i use this spraygun!?1st timer!
Looks like a decent gun.
You would get more answer in the paint and body forum though GL.
Old Jun 15, 2009 | 11:30 PM
HI91EFHB's Avatar
ha so true.what does everyone else think!?
im on a really shxt low budget...about 120bucks evryother week spending money.
Old Jun 16, 2009 | 03:40 AM
19civic93's Avatar
No, it has a 2.0 mm tip. You can use it for thick primers. Have you used any type of paint gun before? This is a conventional gun so pressure and distance is applied differently compared to hvlp guns. Just be aware, if you have only used an hvlp gun before it will be different using a conventional gun. If money's an issue just go to harborfreight.com and buy one of their cheap hvlp guns. It's like 30 bucks. They should come in the tip sizes you need. Check the tech sheets on the paint you're going to use and it will tell you what tip size is required. I would save for a good gun though.
Draiga1988
Paint and Body
May 6, 2011 08:08 PM
cd5owner
Paint and Body
Aug 18, 2007 11:55 PM
fidiv
Jul 19, 2007 08:37 AM
JCracer723
Welding / Fabrication
Dec 15, 2005 04:47 PM
