JRSC on itr motor?
Ok so im thinking about putting a jackson racing supercharger on my C5 and was wondering how much psi i can run on the stock compression. Its a Usdm itr motor and right nom im running crower stage 2 (stock idle design) cams, crower dual valve springs and crower steel retainers, single layer head gasket. But i been kicking around the idea of throwing a jsrc on it and switching back to stock cams and stock head gasket. Can anyone give me some info on doing this. HP numbers and safe psi. Im not looking to be the fastest and i know there are other kits out there that are better. Just trying to get some info
'Your search for "JRSC" in the ITR subforum returned 119 results.' You'll find your answer (and a lot more information) on the first page alone.
If you need proper searching instructions, see this thread: https://honda-tech.com/forums/acura-integra-type-r-8/search-2589198/
