95 civic disc brake swap
I am putting some 2000 acura integra disc brakes on the rear of my 1995 honda civic ex and was just wondering before I tear it apart if the brake lines bolt right on or if i have to splice them.
Anyone that has done the swap know?
the brakes lines go right on. if you have a 4dr and the integra was a 2dr the ebrake cables wont be long enough. drum ebrake cables wont work anyhows. you have to get the cables from the disc brake setup. i had to order mine
A good way to do this is find a SI in the junkyard with rear disc's and swap the hole trailing arm assembly that'll have your emergancy brake cables & rubber brake lines that you need, and might save a bit of money doing so
thanks for the advice but i said i have 2000 acura integra trailing arms with baer rotors sitting in my garage. i was just making sure i had everything before i ripped it apart seeing as this is my daily driver. they have the ebrake cables but the brake lines were cut
elnoyl
Apr 25, 2009 10:00 AM
