jdm hydro b16 tranny w/lsd
bought it with a cracked outer housing, replaced it with my usdm ls tranny housing perfect fit. axel locks in place but i can pull it in and out about a 1/2 inch naturally while driving it stays out more so then in and leaks transmission oil like nobody's business // so bad enough my b20v set up smokes a bit now tranny oil on header smokes .. any suggestions..
p.s : i notice the play in the axel isn't the snap ring ..it feels like the whole assembly inside is moving back and fourth
would u like to elaborate...if possibe can u email me danewslim2@aol.com
on the outer casing, theres supposed to be a shim where the diff goes into. if theres no shim, then the diff will move side to side and cause the axle to push out and in like that.
hughesl
May 23, 2003 08:58 AM
