Scraping Motor on Floor/ B16A in HB
Old Aug 20, 2002 | 04:09 PM
SqueezinEF's Avatar
Default Scraping Motor on Floor/ B16A in HB
Like it says, I have a B16 in 89 HB. I have Ground Control Coilovers with Tokico Blue. I have a two finger gap with stock 14's all around. The ride is nice and smooth but if there is a dip on the freeway, I rub/scrape the motor on the ground. I now have an oil leak somewhere. Is this only because of the springs? Anyone know the spring rate on Ground Controls? If it is the springs, anyone know where to get replacements for just the springs so this doesn't happen anymore? Searched, found nothing....
Old Aug 20, 2002 | 04:57 PM
sleepinEP3's Avatar
Default Re: Scraping Motor on Floor/ B16A in HB (SqueezinEF)
i would say youre best bet is to call ground control and see if they can sell you just some springs for the front.
and talk to someone at GC and find out what spring rates would suit you best.
and what kind of mounts did you use?
Old Aug 20, 2002 | 06:42 PM
E-AT_me's Avatar
Default Re: Scraping Motor on Floor/ B16A in HB (sleepinEF2)
wow... you must have some massive dips in the free-way.. atleast raise it up.. that's why you have coil overs!!
Old Aug 20, 2002 | 06:44 PM
nsxmatt's Avatar
Default Re: Scraping Motor on Floor/ B16A in HB (Rexman)
What mount kit did you use? I know the HCP puts the motor lower than most kits so the hood will clear.
Old Aug 20, 2002 | 08:21 PM
SqueezinEF's Avatar
Default Re: Scraping Motor on Floor/ B16A in HB (nsxmatt)
I have the hasport kit. The car is already pretty high. I don't think that this would be happening if the springs didn't have so much play. I got two/three fingers all the way around. I really do not want to mess with the height because it's set to where the camber is perfect (no unneeded wear). I was hoping to get springs the same height that I guess are stiffer. I was reluctant to call GC but I will probably have to.
Here in SD, one of the freeways was built on a landfill, so it's sinking resulting in huge dips. I know you said that to be sarcastic but here it's actually true.
Old Aug 20, 2002 | 10:17 PM
sitrucjr's Avatar
i just got some skunk2 coil-overs for the 90 integra for my 88 civic,,,the spring rate for them are 500 in the front and 400 in the,,,the regular skunk2 coil-overs for the 88 civic spring rate was 400 in the front and 300 in the back,,,just in case you were thinking of getting stiffer coil-overs
Old Aug 20, 2002 | 10:54 PM
big pete's Avatar
Default Re: Scraping Motor on Floor/ B16A in HB (sitrucjr)
bigger wheels
Old Aug 21, 2002 | 06:33 AM
keithv's Avatar
Default Re: Scraping Motor on Floor/ B16A in HB (big pete)
do you know what spring rate the springs are on the front?
looks like you need to get some stiffer springs in the front. make sure to get some stiffer ones in the rear so you don't have too much understeer.
Old Aug 21, 2002 | 06:37 AM
Mr Furball's Avatar
Default Re: Scraping Motor on Floor/ B16A in HB (breaka_1_9)
maybe get some integra spring rates 400 in front and 300 in back
Old Aug 21, 2002 | 11:21 AM
SqueezinEF's Avatar
Default Re: Scraping Motor on Floor/ B16A in HB (FURBALL B-16)
Thanks all for the input. I am probably going to get new springs or coilovers. I had Skunks and Tok Blues in my Eg and the ride wasn't so bad. I'll probably get those again. Thanks again for the help.
Old Aug 21, 2002 | 11:24 AM
2001civicex's Avatar
i would get some stiffer springs and maybe even stiffer shocks.
slowtegkauai
Suspension & Brakes
Sep 29, 2011 08:05 PM
whitehf
Mar 11, 2007 10:20 PM
threesixes
Suspension & Brakes
Feb 5, 2007 10:11 AM
flipwhip
Oct 19, 2006 05:42 PM
Mr HYDE
Dec 20, 2003 01:32 AM
