Garage cleanup, turbos, ECU, AEM, Sleeved block, R head, etc etc etc
Ok guys, well the time has come. I am moving in a while and starting to clean out the garage. I have a lot of stuff laying around so here it goes. All prices are OBO. Willing to work out shipping as well, pm me.
All items are sold as is.
Things are listed in groups and then pictures are after them.
Listed as
Engine and drivetrain
fuel and ignition
engine management
misc
Full GSR integra set of seats in mint condition. $300
ENGINE & DRIVETRAIN:
84MM AEBS sleeved B18c1 block, wiseco pro-tru dished pistons, probe rods, gsr crank, ARP head studs. Comes complete with sensors etc. 5,000 miles on block. $2200
Type R head with ferrea valves, type r springs. all sensors, vtec solenoid, red valve cover etc. $ 1100
USDM ITR transmission, had the case open, everything looks good. $ pending
Type R intake manifold, all sensors, gasket, everything on the Manifold except TB. $ Sold
Type R TB, all sensors including tps and map, gasket, sold
GSR axles, full set with halfshaft $ Sold
Timing belt covers with all hardward, let me know what you need, $40
OEM b18c, c1, c5 timing belt with approx 1500 miles $30
Crank pulley. $20
Various mounts and brackets including ac, all engine mounts, Mount for b series in civic $15-30
Nkk clutch and pressure plate, GSR flywheel. $120
ball bearing turbonetics turbo, blown needs rebuild, polished housing, .63 five bolt exhaust, water fittings, oil fitting. $150
Small garrett water and oil turbo, no exhaust housing, .42 compressor, good shape. $75
Engine Management
AEM EMS 1020. Works good, was in my teg. $ sold
AEM EMS 1000. Got it in case i wanted to be obd1 $500
HONDATA s200 with boost and data logging, installed on p28. $275
APEXI VAFC2 with all wiring you need and mount for dash. sold
P72 OBD2a Ecu. $ sold
GM 3 bar map with connector for TB. $ sold
OBD2b-OBD1 conversion harness $40
AEM WIDEBAND 2301 single channel UEGO controller with brand new bosch sensor. works awesome with EMS. $ sold
Fuel & Ignition
OBD2 integra gsr distributor. $ sold
Various MSD caps $25
MSD coils $20
Cap with 8.5mm wires $40
MSD 6A box with wiring $120
MSD SCI box $180
Aeromotive A1000 fuel pump with clamps and -10an fittings $275, barely used
GSR stock fuel pump $25
GSR stock fuel feed line $ sold
AEM fuel rail with regulator, blue $ Sold
RC 550cc injectors, almost brand new $ Sold
MISC
Full AC system for integra, with wiring harness for up front. $100 Will part out different lines.
Full power steering system minus resevoir, has AEM TRUPOWER PULLEY. $100
Acura "A" emblems, Carbon Fiber, brand new $25 each or $40 together
GSR stock header $ sold
98-01 integra bumper, oem, needs a little work $35
2.5 inch downpipe with flexpipe $35
Stock integra intake $25
Short ram intake $20
C&R Racing Radiator for Integra. SPAL fan, dual core, BNIB with cap. $350
Single core honda radiator half size with fan, complete $30
Dual core honda radiator half size with slim fan, complete $ sold
BOTH RADIATORS WORK FINE, HOLD WATER, NO LEAKS, ETC.
Greddy intercooler, dented on bottom $ sold
B series starter. complete $ Sold
B series alternators. $40
B18c1 radiator hoses $ sold
Various belts $5
Listed as
fuel and ignition
engine management
misc
Crank pulley. $20
Engine Management
Fuel & Ignition
MSD coils $20
MSD SCI box $180
MISC
Various belts $5
$300 for this stuff below picked up saturday in everett
cash in hand pm me
GSR stock header
cash in hand pm me
GSR stock header
Bump
