oil light comes on at very low idle <--- Is it a bad pump
Old Jun 14, 2009 | 01:24 PM
owneyboy's Avatar
Icon2 oil light comes on at very low idle <--- Is it a bad pump
when i tap the throttle or just drive my hatch the oil light will come on for a split second after i let go of the gas. the idle will be very low and the car would be vibrating like it is about to die. I was thinking it could just be a weird low idle problem but the Oil light comes on only and not alternator light. Is my pump going bad... ?
Old Jun 14, 2009 | 01:26 PM
civic_driver's Avatar
Default Re: oil light comes on at very low idle <--- Is it a bad pump
Could be. Make sure you have enough oil in there and that you try a new oil filter because it might be clogged.
Old Jun 14, 2009 | 01:28 PM
owneyboy's Avatar
oil is amount is good
Old Jun 14, 2009 | 01:38 PM
Ruben19's Avatar
oil pressure test my friend.
Old Jun 14, 2009 | 01:49 PM
owneyboy's Avatar
hmm ill look into that thanks for replies soo far
Old Jun 14, 2009 | 01:54 PM
jake 92eg d16z6's Avatar
i have enough oil in mine all the time its always checked my light does the same damn thing and flickers when drivin so im pretty sure it is
smetzger
Dec 27, 2016 03:16 AM
negusjuda
Jun 21, 2011 12:57 PM
ZXRider
May 30, 2009 04:24 AM
GraphiteMW
Sep 2, 2007 11:07 AM
CRXSIR1
15
Dec 1, 2002 06:56 AM
