H2B ...OBD1 H22 Distributer Wiring in OBD2B Integra..Need HELP ASAP
I own a 2001 Integra Vtec...
OBD1 Jdm H22 Motor/Distributer
OBD1 P72 w/Hondata S300
Everything is wired up....Car cranks..No Spark...!!!!!
We tried 2 different distributers...on both we tried internal and externals coils...
We tried 2 completely different wiring harnesses...
We have power to the distributer....Igniter is Def. Good !
Everything works Just NO SPARK....
All fuses were checked...
The first wiring harness was OBD1 ...everything was pretty much plug + play..
The second wiring harness is OBD2b...and we Re-Wired that Harness and Put OBD1 Distributer clips on that harness...
ANYONE THAT CAN CHIME IN AND HELP ME OUT I WOULD APPRECIATE IT...IM GUESSING ITS PROBABLY SOMETHING VERY SMALL AND STUPID..........!!!!!!!!!!!
1. Have you made sure all your grounds are connected?
2. Have you checked your harness for broken wires? cant tell you how many times i came across this when i was redoing my harness. It was the reason my VTEC would sputter and of course it took a very long time to find.
3. Have you checked all your fuses?
4. Is there an alarm on the car that may be disabling ignition?
5. What base map is on the ecu?
