B20vtec EF owners....what mounts and pistons you using???
Old Aug 20, 2002 | 03:40 PM
Scarface928-Huey Tran's Avatar
Default B20vtec EF owners....what mounts and pistons you using???
I was wondering will the ha-sport(for the b16a)mounts work on the b20?Also could I use the same pistons(stock b20)with the new vtec dohc head?Reason I asked is cause I just got the b20 longblock and with only 19k miles I don't really see any reason of taking the crank and pistons apart.
Old Aug 20, 2002 | 03:52 PM
xtrafastcivic's Avatar
Default Re: B20vtec EF owners....what mounts and pistons you using??? (Huey Tran)
you will need a 90-93 side mount to make the hasport work
yes you can just use the stock block but are you doing this by yourself??
if so good luck with oil leaks
MasterLsGod
Oct 22, 2008 01:10 PM
89hatcher
Nov 4, 2007 05:19 AM
mymeatb18"
Apr 24, 2006 12:16 PM
Hella_Fresh
22
Jan 17, 2005 07:11 PM
