h22 turbo
Old Jun 14, 2009 | 09:28 AM
H22TQ's Avatar
Default h22 turbo
hello. I'm about to do a turbo with low boost on my 98 prelude with an h22a. probably 6-7lbs to be safe. I was just wondering if I should leave the gear that's in it or go with a shorter gear like i was planning to do before i wanted to boost it. also, what would be the best mods for a small turbo set up like that? thanks
Old Jun 14, 2009 | 09:49 AM
Hawkze_2.3's Avatar
Default Re: h22 turbo
I wouldn't mess with the gearing if you want traction. I have an H23 (longer gears) without a turbo and I can spin all through 1st and 2nd pretty easily on a dry surface.
What do you mean by best mods? What does your turbo kit consist of?
Old Jun 14, 2009 | 10:43 AM
carnot's Avatar
I agree, don't mess with the gearing at this point. To start off it may be better to choose a power goal and then we may be able to help with suggestions for your setup. How many miles are on your engine right now? Start by getting some leakdown and compression numbers to have an idea of the internal health of the engine.
Old Jun 14, 2009 | 02:26 PM
RGSH22ACCORD's Avatar
u dont want want to get lower gears and dont get to small of a turbo if will creat e more heat which is not good for an h22
Old Jun 14, 2009 | 04:59 PM
H22TQ's Avatar
well im aiming for a 13.00 to 13.5sec car. im getting a cheapy turbo set up for now. like an ebay turbo kit. my car ran a 14.5 at the track in 60degree weather. so basically i want to knock off a second on my 1/4 mile.
Old Jun 15, 2009 | 06:00 AM
catacon's Avatar
Don't do a "cheapy" turbo setup. That's really just a stupid idea. If you want to boost your car, spend the money and do it right.
Old Jun 15, 2009 | 06:05 AM
NirVTEC's Avatar
x2......you'll end up regretting it and replacing everything anyway.
IMO steer away from Turbonetics turbos......Theyre very good, and a lot of people use them, but the shop I go to has had horrible customer service issues with them when it comes to defects.
don't mess with the gear for now......Wait until you can make a Trans Project out of it
LSD
Final Drive
Flywheel
Axles
Clutch
Old Jun 15, 2009 | 07:16 AM
BlueLude94's Avatar
Then get nitrous
Old Jun 15, 2009 | 08:07 AM
NirVTEC's Avatar
Originally Posted by BlueLude94
Then get nitrous
Na, $500 for 1sec sucks!
LOL!.......The 100 shot should've been more like 1.5+ for me(but was 1.1).....But Drag Radials owned me with ~300whp/250tq!
On a stock motor, I wouldn't even consider a Turbo.....Not enough R.O.I.(return on investment)......Your average Turbo/Stock motor Prelude is stuck in lala land after spending $2-3-5k! Lala-Land aka high 13s-low14s.
Unless you push the envelope and run 10psi+
Old Jun 15, 2009 | 08:19 AM
catacon's Avatar
Yeah, you can get too crazy with a stock H22. The only way to boost one is to build it first. Then you can start having some fun.
Old Jun 15, 2009 | 08:35 AM
NirVTEC's Avatar
Or you make 300-400whp on a Stock H22A and drive around a ticking timebomb with a mercury switch!
Considering most stockish Prelude owners are stock in 15sec-Land, I guess high 13s isn't too bad with a Turbo......but for the cost! nitrous FTW!...
Old Jun 15, 2009 | 08:36 AM
BlueLude94's Avatar
Name anything for less than $500 that will shave off 1 sec of a 1/4 mile time.
Edit: Nevermind, I just sensed the sarcasm, LOL,
Old Jun 15, 2009 | 09:57 AM
H22TQ's Avatar
thanks for help. i think im gonna wait for big turbo project. ive always wanted a turbo car. and idont know about you guys but ive only counted 3 preludes in west orlando,fl. ima stick with the lead sled. civics,integras are a dime a dozen around here. i like the uniqueness even if it costs more to move
edit:5th gen preludes
Old Jun 15, 2009 | 11:14 AM
NirVTEC's Avatar
13.3x@108mph in street trim on DRs with a 2.2x 60' time!
Sorry, some people don't know me here.....I am a nitrous ***** since 2002!
Old Oct 26, 2009 | 05:57 PM
bigblockh22's Avatar
lol thats killer. How many sprays until you start loosing compression?
Old Oct 27, 2009 | 09:56 AM
NirVTEC's Avatar
100lbs and counting smart-***. Over 150lbs total and still making great power N/A.
Still clueless and bumping threads to bait me.
Old Oct 28, 2009 | 07:52 AM
No actually im being serious. I was wondering how many cause I here it shortens engine life quickly. over 150 100shots? still full compression thats pretty good.
Old Oct 28, 2009 | 08:01 AM
NirVTEC's Avatar
150lbs of Nitrous
100 shot = 1lb/10sec Basically 1 pass at the strip
Go here if you're really curious;
https://honda-tech.com/forums/showth...hlight=nitrous
Old Oct 28, 2009 | 10:24 AM
thanks
ludeking1007
Aug 17, 2009 08:33 AM
Mr.Touchdown
Nov 9, 2006 10:02 PM
ateeb786
Sep 23, 2006 06:10 PM
hondaracin24
Mar 26, 2005 02:07 PM
96grnaccord
Jul 28, 2002 08:32 PM
