Hater alert...need some feedback..
Old Jun 14, 2009 | 01:12 AM
FuRiO27's Avatar
Post Hater alert...need some feedback..
ok here it goes i have a 94 Gsr..its my daily ive had the car for 2 years ive put a lot of hard earned cash into it.couple weeks ago i was at a friends bbq in arcadia. when i walk out to go home round midnight. get in my car only to find out that some fkn hater had broke in i guess tried to steal it but couldnt but what they did next was pop my hood rip ignition wires and headlight wires (HiD)..and worst of all put wood chips in my motor..(where you would normally pour oil in) i wanted to know what would the best way to fix this??i have couple of ideas.. but would appreciate some feed back from my honda tech community...im also investigating who did this..bcuz ill get back at them 10 times harder!! cowards!! wel yeah hit me up with some ideas..this happen may 30th.
Old Jun 14, 2009 | 01:17 AM
jasoncanseeoh's Avatar
Default Re: Hater alert...need some feedback..
Take off your valve cover...
Get a shop vac or some ****...
Turn it on and do work...
(You can probably even just pick the wood chips out)
Shouldn't be too bad really. Unless you decided to be an idiot and run your motor after they did that.
PS- Don't get back at them. Trust me.
Old Jun 14, 2009 | 01:18 AM
teggyboy's Avatar
hmm you might want to take it to a shop/tech to make sure if it has any other problems besides the ones you've listed and to get it fixed.
Sorry to hear that. First time I heard anything about putting wood chips in a motor >.<
Old Jun 14, 2009 | 01:21 AM
FuRiO27's Avatar
i already did what i could with the vac..but i could still see some in the oil..and of course i didnt turn it on..i knew it would make it worst..
Old Jun 14, 2009 | 05:23 AM
Dogginator's Avatar
Daisy... Daisy...
You should most likely pull the cams to lift the rockers and clean beneath them. Pics?
Old Jun 14, 2009 | 06:58 AM
95DC2GS-R's Avatar
F*ck thieves and haters!! I hate the fact that we can't even keep our cars safe any more. This is the same reason I don't bring my car to an event like that, I'll ride with a friend.
I would visually inspect everything, and change the oil just for good measures. Pulling the cams and rockers would be good, but if you're not too keen on the mechanics of the motor and valve train I would not advice it because you have to slip off the timing belt and all that.
Old Jun 14, 2009 | 10:51 AM
FuRiO27's Avatar
any ideas on how much it would run?? because this is something i dont wanna try to fix myself..i cant afford any errors..
Old Jun 14, 2009 | 10:58 AM
Dogginator's Avatar
Daisy... Daisy...
If it was just wood chips without any sand or grit, you should be fine with the head cleaning. Block the oil drain holes.
Old Jun 14, 2009 | 11:16 AM
FuRiO27's Avatar
theres a little dirt in it..i was thinking taking off the oil pan and draining it all out and then used engine flush cleaner..but not really set on it..its only in my first 2 valves..
Old Jun 14, 2009 | 11:23 AM
Dogginator's Avatar
Daisy... Daisy...
Check the location of the drain ports. If it didn't go down one, don't worry about it.
Old Jun 14, 2009 | 11:28 AM
ALLxMOTOR EG's Avatar
Vietnamese!
Damn haters and thieves.
Old Jun 14, 2009 | 11:38 AM
FuRiO27's Avatar
where exactly they located?? bcuz right now im trying to wire the head lights back..so i can check...
Old Jun 14, 2009 | 11:47 AM
Dogginator's Avatar
Daisy... Daisy...
Pull the valve cover and look on the in front of the exhaust rockers. There are three holes about 1/2" diameter IIRC.
Old Jun 14, 2009 | 11:57 AM
hot_rice's Avatar
so much haters around
Old Jun 14, 2009 | 12:25 PM
FuRiO27's Avatar
everything looks fine everywhere else..just those 2 valves..you think it worth taking it to a mechanic?????
Old Jun 14, 2009 | 12:27 PM
Dogginator's Avatar
Daisy... Daisy...
Wood chips usually do not spontaneously migrate. If it is visibly clean, you should be good.
Old Jun 14, 2009 | 12:29 PM
FuRiO27's Avatar
why cant haters just fix up their own cars instead of hating on others...
Old Jun 14, 2009 | 12:31 PM
FuRiO27's Avatar
it does look muddy in there like some dirt is in there...
Old Jun 14, 2009 | 11:03 PM
FuRiO27's Avatar
does anyone know a shop that would be good to take it to??im in so cal 626 area.
Old Jun 14, 2009 | 11:19 PM
Jimmy's Avatar
Global Moderator
Unfortunately a lot of people are jealous or don't have anything better to do so they mess with peoples **** and vandalize cars. Karma will bite them in the ***.
It would be much easier if you could post some pic's. You might haft to pull the head off to thoroughly clean it out. You might be able to remove the cams/valve train and grab a couple cans of brake parts cleaner and a bunch of shop rags.. If you do this i would suggest starting the engine after everything's clean let the oil circulate and then change your oil.
Old Jun 14, 2009 | 11:30 PM
fuNk`'s Avatar
these kind of people make it hard to enjoy our toys
Old Jun 15, 2009 | 03:34 AM
jhammond_82's Avatar
Reject Papi
what a jack ***. people need to grow the **** up. i hate stupid people.
Old Jun 15, 2009 | 06:00 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Distance yourself from your "friends" at that bbq, because you know it was somebody there that did it.
Pissed anyone off lately? I guess it could also have been just some random person that rolled by and recognized your car if you pissed them off in traffic or something. Is your car modded to the point that someone could easily remember it?
Old Jun 15, 2009 | 06:29 AM
S2Integra's Avatar
Vandalism is a crime, don't be as stupid as they are, do it legally
Old Jun 15, 2009 | 07:29 AM
Reject Papi
i agree. don't go out looking for vengance. but call the police? file a report?
