gsr rebuild 220whp!!!!!???????
I’m rebuilding a GSR motor and I hope to pull 220 whp.
ECU: Honda s300 and tuning it at low cash racing in phoenix
Block:
-oem main and rod bearings
-oem rods with jdm itr pistions
-oem crank
-n1 ctr crank pulley
Head:
-Skunk 2 pro series manifold with a hondata head gasket
-blox 70mm tb
-custom ram air intake
-Super tech valve train with flat face valves
-a mild port and polish
-skunk 2 cam gears
-I haven’t decided on what cams shafts I should buy….bc stage 2 or skunk 2 pro 1
-blox max flo header
So is it possible to pull 220 whp with my setup and a good tune on 91 oct.
Thanks guys
Block:
-oem crank
Head:
-blox 70mm tb
-skunk 2 cam gears
Thanks guys
slofton77
21
Mar 10, 2011 01:09 PM
