P28 auto/manual????'s
Old Aug 20, 2002 | 03:07 PM
hondafrk's Avatar
Default P28 auto/manual????'s
what is the difference between the auto and manual models of the p28 ecu?
me and Forcfedcivic are dropping a z6 in my eg and the only p28s that I can find in my area that are reasonably priced are the auto ecus. I have a manual
will the auto ecu work or will it pop some codes or something?
Old Aug 20, 2002 | 03:26 PM
splitime's Avatar
Default Re: P28 auto/manual????'s (hondafrk)
I would get more info from others on this, but supposedly you can get the auto and make some changes to it switch it to manual. If you can find manual though get that, would mean no fiddling inside. I dont know how to do the auto ecu to manual, but i'm sure someone mentioned you could, i was asking something similar a week or so ago.
Old Feb 19, 2003 | 10:11 AM
nerdsports's Avatar
Default Re: P28 auto/manual????'s (splitime)
bringing this back from the dead....... ever got an answer??? i bought an auto p28 and i need to know this as well...
Old Feb 19, 2003 | 10:23 AM
JDM_Sol's Avatar
Default Re: P28 auto/manual????'s (nerdsports)
my friend had a auto p28 ecu with his manual eg.....it idled funny.....but there are shops there that can convert the ecu to manual.....because now his engine sounds fine......
Old Feb 22, 2003 | 06:22 PM
TurboTeG4's Avatar
Default Re: P28 auto/manual????'s (JDM_Sol)
Well ive been through with it, acutally i had a d16z6 swap with a manual computer on an automatic tranny. Well it just wont work for u in the long run, for me i couldnt idle too long i had to put the auto tran in neutral at stops when hot. Im assuming that your situation would be the same as mines in a different way. Im positive 100% you should go with the standard ecu.
Old Feb 22, 2003 | 08:58 PM
xXx Justin xXx's Avatar
Default Re: P28 auto/manual????'s (turbocivic4)
you would have to have the ecu sent out and converted to manual... which would cost like $50 i think? i remember having the same questions when i did my z6 swap in my old crx back in may. i think the fuel curves might be different.. or i might be imagining things. also the revlimiter is set different, has automatic shift points...( which is why i think the rev limiter comes in earlier... stops reving b/c it is supposed to be shifting?) just shell out the damn cash and buy a manual one.... only should be like $150 shipped.... post in the classifieds on here..
civicfrog
Feb 4, 2013 04:00 AM
blink_977
Oct 28, 2009 09:50 AM
sicksiguy
Feb 7, 2007 08:33 PM
lazyvietboi
Aug 6, 2004 03:03 PM
HybriDNA
Dec 10, 2003 06:31 PM
