spoon mirrors/
Most mirrored surfaces can be swapped out for plain as long as you can find someone who makes the mirror in that exact same shape. Your best bet is to go back to Spoon and see if they make a replacement mirror glass for your mirrors. If they do, they will likely have that shape in different finishes.
Otherwise, most glass dealers should be able to cut a mirror into that shape. I have no idea about the cost there but it isn't too hard to do. You would then have to pull apart your mirror and swap the glass out.
//www.spoon.jp/eng/
//www.spoon.jp/eng/
