GSR rebuild / JDM ITR Pistons (81.25mm)
I'm going to start rebuilding my block in about a month since my rings are bad.
The head was rebuilt a few months ago to fix a problem with a couple stem seals.
Since I'm using all OEM parts, my question is.....
Should I go with JDM ITR pistons (81.25mm)? Is it worth the few extra bucks? (Planning on letting the machine shop put the block back together)
Just looking for a little umph....
If you'll be staying naturally aspirated, I'd recommend using b16 pistons (either pr3 or p30). You'll get a bit more compression and you won't have to modify your stock rods.
importboi22
Jan 31, 2005 10:28 PM
