97 honda civic with jdm h22 won't start after it shut off
Old Jun 12, 2009 | 07:35 PM
Jdog906's Avatar
New User
Default 97 honda civic with jdm h22 won't start after it shut off
I recently had my civic cut off on me when I was coming home. The car will turn over but it denoting like it ain't getting fuel and it back firing. I changed the fuel filter and it's getting fuel to it. I checked the fuel pump and it's pushing gas out and to the filter. I have spark on all my plugs. I'm going to test the psi on the fuel rail bc I was told could be fuel pump if it ain't pushing out the psi. I'm running out of ideas here guys someone help me here.
Old Jun 12, 2009 | 07:37 PM
Former User's Avatar
Default Re: 97 honda civic with jdm h22 won't start after it shut off
Check whether the timing belt slipped.
Is the CEL ON?
Old Jun 13, 2009 | 04:54 AM
Jdog906's Avatar
New User
yes cel is on but it's always been on since I own the car. The swap was done poorly
Old Jun 13, 2009 | 07:24 AM
Have you checked the cam and crank timing?
Pull the CEL codes from the ECU as described here. Then reset the ECU to see what codes return after cranking the engine.
Got Honda
14
May 19, 2025 09:46 PM
dre33333
Dec 2, 2020 07:24 AM
stray1
20
Sep 3, 2013 12:52 PM
ChilBlu92
14
Jul 30, 2009 08:30 PM
Vinny97lude
Apr 16, 2004 06:02 AM
