Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Look what came in the mail (Hondata Inside)
Old Jun 12, 2009 | 12:00 AM
Leo's 07 Honda Civic Si's Avatar
Default Look what came in the mail (Hondata Inside)
Here is the thread on how i got 2nd http://www.*************/forums/intr...utomotive.html
well since i cant link the thread here it is
I got 2nd place which means i get 50% off the Flash Pro :woowoo::dancing:
08 Civic Si Mods:
Skunk2 Header
Skunk2 70mm
Injen CAI
Eibach Sportlines
SSR Type-F 17x7.5
Toyo R1R
Mugen Visors
JDM H Emblems
Dyna Pack Dyno:
Stock ecu 170.4 tq 233.4 hp
Flash pro 175.2 tq 237.2 hp
Thanks to the guys at :roject Import:: technology & spirit for helping me out with my car and for being there at the dyno
Here are the vids on my channel
http://www.youtube.com/user/Leonard21
:vtec:
If any one in the OC/LA area and need work done to their car these guys are the guys to go to Project Imports. They have been working on hondas for years and they can do just about everything.
1300 S. Anaheim Blvd.
Anaheim, CA 92805
714.808.0222 PH
714.808.0232 FX
Old Jun 12, 2009 | 12:39 AM
h22 kid's Avatar
Default Re: Look what came in the mail (Hondata Inside)
hey im in your area anaheim to be exact i need to get my car tuned. maybe i will consider them
Old Jun 12, 2009 | 02:37 AM
RICO_'s Avatar
NO MERCY!
Wow. Those Dynapacks really DO read high numbers.
Congrats anyway!
** Edit ** - I just saw the top of the graph.....Fly Wheel Power/Torque.
Old Jun 12, 2009 | 07:13 AM
08SiFreak's Avatar
you're all about shwoing off aren't you? and why does the certificate say "06" and you're user name says you have an 07? Also the certificate says "most powerful Si" and then under it it says you're the 2nd highest
Old Jun 12, 2009 | 09:33 AM
100miles+'s Avatar
From: In Diamond Bar, CA Brake Boosting like a Mother Focker!
4 more hp and 5 more tq and thats gains? WTF? how much did you pay for the flash pro thing?
Old Jun 12, 2009 | 09:43 AM
Greg50Lt's Avatar
ha ha ha most powerful/2nd powerful. And wow flywheel power. I wonder how much my car makes to the flywheel. Lastly 5 hp for a $700 dollar tuning peice not including the price to get it tuned.
Old Jun 12, 2009 | 10:00 AM
K5^'s Avatar
K5^
Brand New
The full potential of the the motor/f-pro has yet to be exploited.
Old Jun 12, 2009 | 10:39 AM
ha ha I love noobs
Old Jun 12, 2009 | 10:44 AM
K5^'s Avatar
K5^
Brand New
Why is that people only insist on looking at peak power and torque gains? Anyone else see the gains in the midrange? The early cross over is a nice touch, but takes away from the renowned VTAK switch.
Old Jun 12, 2009 | 10:48 AM
QFTMFT
Old Jun 12, 2009 | 10:50 AM
Zeusone's Avatar
get a real car.
Old Jun 12, 2009 | 10:59 AM
RICO_'s Avatar
NO MERCY!
31 ft/lbs. of torque and 36 HP increase from an Si with untuned boltons.
This is why I'm convinced never to use a Dynapack dyno.
Old Jun 12, 2009 | 11:47 AM
i-VTEC_DOHC's Avatar
yea i made an appointment for today at noon with church's and i cancelled it because they use the dynapack. if there was a turbo si there you wouldnt have gotten second
but congrats!
Old Jun 12, 2009 | 05:48 PM
thats the most dumbest reason to cancel also it was only for n/a motors
Old Jun 12, 2009 | 06:18 PM
why? its a 2 hour drive and they use the daynapack. i want the rollers to get real numbers.
Old Jun 15, 2009 | 12:45 PM
kgibson16's Avatar
this has nothing to do with the dyno its the man who 's sets it up before the tune. dynapacks dont use rpm pickup like dynojets. they use gear ratio to figure rpm and if its not properply set up your #'s are gonna be all over the place
but congrats!
lol i hope your joking. like i said before above there's nothing wrong with dynapack's its the user inputing the info into the computer. besides dynos are nothing but tuning tools and absolutely prove nothing.
Old Jun 15, 2009 | 12:58 PM
kgibson16's Avatar
here's some nice dynapack reading from shawn church himself.
Quote: Originally posted by Shawn Church on Feb/15/06
A Dynapack is a chassis dyno that uses hydraulic loading to test and measure the output of an engine. A chassis dyno is a tool that measures engine output while the engine is still in the car (vs. an engine dyno, which measures output on a test stand without transmission, etc.).
Chassis dynos use one of two basic means to test engines. One is inertial loading, where a large mass of known inertia is accelerated by the test vehicle. This is a simple, but somewhat limited method for testing. The other method, used by Dynapack, involves a load control mechanism that places an operator controlled load on the engine using electrical (eddy current) or hydraulic (fluid pressure) systems. The advantage of a load control type dyno is the ability to simulate a wider variety of real world situations on the dyno. Additionally, because operating conditions can be fixed, hp changes are far easier to measure.
The final difference between a Dynapack and virtually all other chassis dynos on the market today is that the Dynapack eliminates the tire to "road" interface. By using a special hub adaptor that replaces the wheel and tire, the Dynapack eliminates wheel slip, alignment losses, tire inflation/wear issues and more. However, by eliminating the large mass (and attendant inertia) of the wheel and tire combination, the Dynapack does tend to read higher than comparable "roller" dynos.
How much higher a Dynapack reads is often the source of consternation and debate among enthusiasts wishing to compare numbers across different dyno types. Our first response is, "don't bother". We feel that the primary purpose of a chassis dyno is to measure differences from parts changes, tuning and the like. However, we also understand that bench racing is very common, and trying to ascertain where one stands versus a competitor is a valid pursuit. In light of this, we've undertaken a brief (and simplified) physics calculation to give people some ideas of how a Dynapack measurement will vary vs. the most common inertial dyno, the Dynojet 248C (let's give credit where credit is due, the Dynojet revolutionized the chassis dyno market and brought dyno availability to the masses).
There are two primary differences between the Dynojet and the Dynapack. The first is very clear when you see them. The Dynapack requires removing the drive wheels and tires from the test vehicle. The second is that the load time (the time it takes to accelerate the test vehicle over a specific rpm range) is operator controlled (and fixed if so desired) on the Dynapack. On the Dynojet, load time is controlled by the amount of hp produced, and by the gear ratio chosen by the operator. We will address both of these in our calculations. (all calcs will be done in metric terms and we will convert to more commonly used hp and lbs-ft at the end)
The first concept we need to understand is that of inertia. In particular, the inertia of a rotating mass. For this we will need to know something called "Moment of Inertia" or MoI as we shall call it. MoI uses the term kg-m^2. MoI is basically dependent upon the mass of the object, and how far that mass is distributed from the center of rotation. The higher the mass, or the further it is from the center of rotation, the higher the MoI.
In order to calculate the MoI of a wheel tire combo, we really need to measure the particular wheel and tire. However, we can easily make some reasonable estimates based upon what we do know of the wheel and tire.
Let's start with a couple of typical FWD wheel and tire sizes (since we had a couple lying around the shop to measure). First, a 17"x7" wheel with a 215/45/17 tire. The tire has a mass of 10.86 kg. The wheel has a mass of 8.5 kg.
We will approximate the MoI of the wheel by using a point mass model where the MoI (or I) = mr^2. To approximate our 17" wheel with spokes, we will use a 15" effective diameter as a rough estimate.
Thus, the MoI of the wheel is (8.5kg*(.1905m)^2)) = 0.3085 kg-m^2
We shall use the same equation to calculate the MoI of the tire, using the outside radius (24") less a small correction (1") since most of the mass of the tire is concentrated in the belt and tread surfaces.
Thus, the MoI of the tire is (10.86kg*(.2921m)^2)) = 0.9266 kg-m^2
Making our total MoI for a single wheel/tire = 1.2351 kg-m^2
Now that we know the MoI, we must determine the angular acceleration of the wheel/tire to calculate total torque required to accelerate the mass. On our Dynapack, for the typical street car, we use an acceleration rate of 500 rpm/sec (engine rpm) during ramp runs. With a 4:1 total gearing reduction (not unusual for a 4th gear run), our acceleration rate at the hubs is 125 rpm/sec. This equates to 2.0833 rev/sec^2, or 13.09 rad/sec^2.
When we multiply MoI by the acceleration rate in radians, we end up with a torque in newton-meters (kg-m^2/sec^2) = 1.2351 kg-m^2 * 13.09 rad/sec^2 = 16.168 N-m or 11.93 lbs-ft of torque. This is the torque required to accelerate a wheel with our calculated Moment of Inertia at the rate described. However, since most dynos return a torque calculated by measuring wheel torque and then dividing by gear ratio, the difference in dyno torque as printed on your dyno sheet would be 11.93 lbs-ft/4 = 2.98 lbs-ft. Finally, since this is per wheel, on a two wheel drive car, the total torque loss would be 5.96 lbs-ft.
Thus, the minimum expected difference between a Dynapack and a Dynojet (for this particular wheel/tire combo) would be 5.96 lbs-ft of torque (the Dynapack would read higher). If we were making peak power at 8000 rpm, we would expect the power difference to be approximately 5.96(8000/5252) = 9.08 hp. This is the difference solely attributable to inertia, and assumes that the acceleration rates on both dynos are the same.
These losses do not take into account rolling drag, tire scrub or tire flex (related to inflation pressure, vehicle weight and strap down tension). In testing on Dynojets, we have found that a change in camber of about 2 deg can result in a 5-6 hp change in measured power. However, these are extremely difficult to quantify - but be advised, they do exist on roller dynos, but not on the Dynapack (thus another source of differences).
As power increases for a given combo, the difference will grow due to the change in acceleration rate on the Dynojet (assuming the same gear is used for all tests). As the acceleration rate goes up, the total torque required to accelerate the wheels and tires will go up (remember, the torque calculation is MoI * acceleration - twice the acceleration rate requires twice the torque). But on the Dynapack the acceleration rate is kept the same (or at least should be), so losses remain largely the same. Furthermore, both dynos are subject to inertial losses accelerating the flywheel, transmission, etc. and the faster acceleration rate as hp climbs will show increasing losses on the fixed load Dynojet.
This is why we recommend people use a rough percentage adjustment to estimate flywheel hp on the Dynojet versus a rough fixed adjustment on the Dynapack. In our experience, a manual transmission FWD car will lose 20-25 hp to the hubs on the Dynapack. A RWD car will lose 25-30 hp and an AWD car about 35-40 hp (the FWD case has been verified on an engine dyno). In contrast, losses on the Dynojet will be in the 12-14% range for FWD and 14-16% for RWD (opinions vary).
Let's work through a comparative example for the same car on a Dynapack and Dynojet.
Car A produces 205 hp to the hubs on the Dynapack. This would equate to between 225-230 hp at the flywheel. The same car produces 195 hp to the rollers on a Dynojet. This would equate to 222-226 hp at the flywheel. Furthermore, the difference in power matches up very well with our calculated difference due to inertial losses. And interestingly enough, we have tested just such a car on our Dynapack and a Dynojet back to back with the same results (actually 196 vs. 206 hp).
Let us then assume that we modify Car A to produce 25 hp more at the flywheel (maybe a good head port and set of camshafts). The car would now produce almost 230 hub hp on the Dynapack, but on the Dynojet it would produce 217.5 hp. Same car, but the difference between the two dynos has grown from 10 to 12.5 hp, largely due to inertial effects.
Please keep in mind that these are rough approximations based upon some loose physics and real world experiences. But they should provide a better insight into the difference between loaded and inertial dynos, and hub vs. roller dynos, along with assisting the user in trying to compare results across the different systems.
Old Jun 15, 2009 | 02:07 PM
dirtySOHC's's Avatar
cleaned up the midrange real nice. I bet it feels awesome.
Old Jun 15, 2009 | 02:35 PM
kartman5's Avatar
You can't go wrong with Churches. They know what there doing and are a quality set-up!
Old Jun 15, 2009 | 04:14 PM
i want real time numbers that i will be putting down when im driving.
u cant drive a lowered si without wheels
Old Jun 15, 2009 | 06:22 PM
WTF does it matter what numbers your putting down when you're driving.
"oh **** I make 100hp to the wheels...can you feel it?"
Old Jun 15, 2009 | 08:04 PM
K5^'s Avatar
K5^
Brand New
Now I know I am quite the neophyte when it comes to dynos and what not, but can you not simply input correction/environmental factors when pulling runs? This way you can dictate what kind of numbers you get despite what type of dyno you decide to use.
Old Jun 15, 2009 | 08:37 PM
it does matter. the fact that the dynapack reads higher numbers than the dynojet, discourages me from using it.
lets just say my personal preference is for the dynojet ok?
now f*ck off.
Old Jun 15, 2009 | 08:56 PM
now f*ck off.
maybe when you stop talking out of your ***. you run all up and down this forum like you know ****.
Old Jun 15, 2009 | 09:39 PM
kgibson16's Avatar
now f*ck off.
why would it matter if one reads higher than the other? you either didnt read my previous post with churches summary or u dont understand what he's talking about. if anything u got your info backwards. dynojets are inertia dyno's which is less like real driving conditions. the only load being put on the car is the weight of the roller's. it measures power from how fast it can turn the rollers. dynapak's are load dynos and the the load is adjustable on them. dynapaks create more load which is more like real driving conditions and not spinning the weight of rollers like the dynojet.
