problem after problem with trans
Old Jun 11, 2009 | 11:05 PM
cadeMFjohnson's Avatar
Default problem after problem with trans
installed new trans. now the latest problem is a bad oil leak from it. i believe it to be the shift rod seal. is this as easy to change as it looks, before i get under the car? just push the pin out, pull off the rod and pry the old seal off with a screwdriver?
