Lower Temp Thermostat
Old Jun 11, 2009 | 10:13 PM
nothing_shocking's Avatar
Default Lower Temp Thermostat
Do you guys see any advantage to running a 170* thermostat in a d16z6 as opposed to the stock one? As in, more power, better running engine, anything good?
Old Jun 11, 2009 | 10:19 PM
r_Senik's Avatar
Default Re: Lower Temp Thermostat
no. it just make your fan click on faster.
thats what i think. i only use cooler temp thermo.
Old Jun 11, 2009 | 10:30 PM
AP2FTW's Avatar
stock brah
Old Jun 11, 2009 | 10:34 PM
dannyboi_86's Avatar
if u use a low temp thermostat , it opens earlier therefore it will never get to hot before allowing coolant to go thru , same applies with fan switch ,if ur changing thermo change the switch also...
torino420
May 5, 2013 08:07 AM
RuneRavenX
Apr 2, 2013 04:45 PM
turboef90
Nov 3, 2008 11:19 PM
