100% lost on how to install this headunit...
Old Jun 11, 2009 | 07:15 PM
GSR-EG-92's Avatar
Default 100% lost on how to install this headunit...
Im not a audio person (I suck at it) and Im lost on this one. This is a brand new sony head unit going into a 96 Civic CX. Im not sure what to do here, no instructions (unit was given to use) can someone help me out? There must be an easy way to do this.
This harness is in the dash
This is from the headunit
Old Jun 11, 2009 | 07:38 PM
jdmb18hatch's Avatar
Default Re: 100% lost on how to install this headunit...
you need the harness to plug into the radio. metra 70-1720, 70-1720t to retain factory keyless entry.
mrdeadman's Avatar
They let me pick
Buy a harness converter, it clips into the stock harness, then you wire it to the open wires from the head unit.
You will need a pinout diagram for your car's harness.
You should also get a dash install kit for your car.
For the harness:
http://www.scosche.com/
And for the install kit use the metra dash install kit for your car.
Old Jun 11, 2009 | 09:20 PM
BROSEPH's Avatar
whatever you do don't trust a major electronics chain to install it, this is how i ended up with solder on my floormats
Old Jun 12, 2009 | 09:36 AM
98civdx's Avatar
Master Detailer
you need a harness to plug into that, and then splice into your deck harness.
i think i have a diagram lieing around here somewhere for the car harness. then you just need to find out what color wires on the deck harness do what.
its really simple. you can either solder the wires or use butt connecters.
Old Jun 12, 2009 | 10:47 AM
8520's Avatar
You guys are over complicating this, a lot.
Buy a harness for your car, ie the ones jdmb18hatch said, and then match color for color.
Old Jun 13, 2009 | 07:48 AM
ken9's Avatar
He's right. Just have to buy a harness and match the colours to connect it. This's much eazy for me than hooker up alarm. =/
Old Jun 15, 2009 | 11:52 AM
hometheaterman's Avatar
Yep buying a harness is the best way. You can cut the stock plug in the car off and wire it up that way but it's a pita if you ever want to go back to stock and can't find that plug to solder back in. You are much much better off just buying the adapter harness as they are cheap anyway.
kornerk12
Audio / Security / Video
Nov 4, 2008 12:37 PM
GuCCi_GSR
Oct 27, 2008 05:09 PM
biglos
Honda Civic (2006 - 2015)
Dec 9, 2006 04:01 PM
justint
May 19, 2006 04:51 AM
pinoyboiwonder
12
Feb 24, 2006 05:45 PM
