Where is the thermal switch for radiator fan?
Old Jun 11, 2009 | 04:46 PM
Mechatronics's Avatar
Default Where is the thermal switch for radiator fan?
This is for a 93 delsol 1.6 si.
the fan does not come on. I have tried two possible connections. One at the base of the upper hose on the block at the 9 oclock position, and one at the rear of the engine on the thermostat housing. So those are not them? I jumper both go no fan action. I did not know there was a relay so that is a possibility? I jumpered the fan to the battery so it does work. Also, is the relay in the engine compartment and clearly labeled? How about the mini diagram on the relay?
Need a quick reply if possible
Thanks
adiaz91
Apr 13, 2019 01:25 PM
asoRm
Aug 13, 2014 12:10 PM
ek98
Aug 10, 2009 12:50 PM
PearlBlueType-S
May 1, 2006 11:58 AM
