obd0 chip in obd1 p28 ecu
Old Jun 11, 2009 | 03:04 PM
GABOCRX's Avatar
Default obd0 chip in obd1 p28 ecu
I can install a pr3 obd0 chip into a p28 ecu? Bove are 28 pin.
Old Jun 11, 2009 | 03:56 PM
Spunkster's Avatar
Default Re: obd0 chip in obd1 p28 ecu
no
Old Jun 12, 2009 | 07:44 AM
Relic1's Avatar
can you install it? yes
will the car run? maybe
will it run well on the OBD0 maps? absolutely no
will you have a CEL? yes
should you give up on this idea? yes
(unless you're trying to reuse the chip and plan to erase it to put in an OBD1 bin)
Old Jun 12, 2009 | 08:48 AM
GABOCRX's Avatar
Thanks, is just for a test. I have a b16 obdo with some bolts on and make the swap to obd1 but I have a problem the engine start fine and make the idle perfect but dont acelerate its start stalling, I using a p28 ecu with p30 map (stock b16). Any ideas.
border919
May 16, 2009 07:44 AM
KHMERXB0I213
Jan 26, 2008 07:48 PM
cua0
Sep 14, 2005 04:53 AM
89silverb16crx
15
Apr 14, 2004 10:02 PM
