Jun Cams Type 3
Old Aug 20, 2002 | 12:43 PM
TypeR582's Avatar
Default Jun Cams Type 3
I wanted to know what your guys cam gears are set for jun type 3 cams and their set up and if what your power gains from the cams.
Old Aug 20, 2002 | 12:52 PM
Hybrid ctr's Avatar
Default Re: Jun Cams Type 3 (TypeR582)
there aren't any optimal settings
every engine is different
Old Aug 20, 2002 | 06:35 PM
ITR 99's Avatar
New User
Default Re: Jun Cams Type 3 (Hybrid ctr)
ok a different question then
whats the max u can advance intake/exhuast cams without getting pition to valve contact issues
Old Aug 21, 2002 | 01:47 PM
TypeR76's Avatar
Default Re: Jun Cams Type 3 (ITR 99)
IN 1.5 degree advance or retard and the same goes for EX.
Old Aug 21, 2002 | 02:38 PM
GSRfoedoe's Avatar
Default Re: Jun Cams Type 3 (TypeR76)
i know u might think its alittle extreme but i had mine at +4,-1 but thats just my motor i dont know bout yours. so head to the dyno and find out. good luck
Old Aug 21, 2002 | 03:04 PM
NW94RS
Guest
Posts: n/a
Default Re: Jun Cams Type 3 (GSRfoedoe)
jun owns toda sucks :flamesuit: activated
every motor is diffrent, took three hours of dyno time to get mine fight, to each his own.
Old Aug 21, 2002 | 04:56 PM
stretracr's Avatar
Default Re: Jun Cams Type 3 (dc-2R)
According to jun you can only move them plus or minus 1deg. Trust me I found out the hard way. I'm now on my 3rd motor. To be safe you can always clay your motor and see how far you can move your cam gears.
[Modified by stretracr, 5:58 PM 8/21/2002]
Old Aug 21, 2002 | 05:17 PM
Chubz's Avatar
Default Re: Jun Cams Type 3 (stretracr)
always nice to know your tolerences! nothing like hitting the dyno and hearing your engine munch on your valves
Old Aug 21, 2002 | 05:22 PM
1 2 NV's Avatar
Default Re: Jun Cams Type 3 (GSRalph)
i got JUN 3 cams, no dyno #s yet, but i would guess that it also depends on if u have aftermarket pistons or stockers. i advanced my intake cam 1 full degree ( 2 degrees on the crank) and had no issues. every motor is different but i would assume someone like jeff (importreview) would have the best knowledge with different pistons because he prolly tunes more JUN powered cars than anyone.
Old Aug 21, 2002 | 05:42 PM
MackSpeed-616's Avatar
Default Re: Jun Cams Type 3 (hondaatwsu)
mine are +4i, +2e
i make 209whp and have run a best of 13.2@104 in 95 degree weather.
Charltons_Trix
17
Apr 30, 2008 02:33 PM
JDM*Fiend
Jun 18, 2007 05:05 AM
SJTrance
May 8, 2004 07:55 AM
topspeed86
24
Jul 21, 2003 02:23 PM
ImportReview
Jan 25, 2002 06:59 AM
