Okay now what the hell is this chunk out of my tranny drain hole?!? HELP!!
Old Aug 20, 2002 | 12:39 PM
Quik89Si's Avatar
Default Okay now what the hell is this chunk out of my tranny drain hole?!? HELP!!
Is this supposed to be like this? It's a 1989 CRX Si, with the stock motor and (as far as I know) stock tranny.
What the hell is that?!? Is that normal?
Alex
Old Aug 20, 2002 | 01:10 PM
Quik89Si's Avatar
Default Re: Okay now what the hell is this chunk out of my tranny drain hole?!? HELP!! (Quik89Si)
Come on guys, someone's got to know if that is supposed to be there or not, or if it matters...
Alex
Old Aug 20, 2002 | 01:22 PM
Quik89Si's Avatar
Mmkay guys, that's not the tranny fill bolt...it's the access to the mainshaft snap ring. Somehow my lack of mechanical and honda knowledge just set my project back by over an hour.
Lock this thread please, no use to me anymore...
Alex
Old Aug 20, 2002 | 01:23 PM
Jeff C's Avatar
yes that is supposed to be there. that is the countershaft nut you are looking at. that is where you access the snap ring when you take the tranny apart.
i am putting my tran back together and that stupid snap ring is holding me up. man it helps to have the correct tools on hand.
Old Aug 21, 2002 | 06:55 AM
keithv's Avatar
Default Re: Okay now what the hell is this chunk out of my tranny drain hole?!? HELP!! (Jeff C)
that is not the tranny drain hole. like jeff c said, you use that to pull the two halves of the tranny case apart.
the drain hole is a very small rounded bolt with a 3/8" ratchet insert. the fill bolt is a 17mm up to the left (when looking from the passenger's side).
[Modified by breaka_1_9, 11:17 AM 8/21/2002]
Old Aug 21, 2002 | 07:17 AM
Quik89Si's Avatar
Default Re: Okay now what the hell is this chunk out of my tranny drain hole?!? HELP!! (breaka_1_9)
Yeah I found everything and started to try to do it...but the fill bolt won't come off, and I'm not touching the drain bolt till the fill bolt comes off!!! Thanks for the help though guys...
Alex
Old Aug 21, 2002 | 07:52 AM
zcivic91's Avatar
take a 17mm box wrench and then put another box wrench on that for an extension..its hard to explain but its alil trick i know for an extension.
Old Aug 21, 2002 | 08:30 PM
specie's Avatar
I accidentally fill the oil using the hex one. If I open the 17mm nut next to the CV joint, everything should drain out to the right level, right? Thanks.
Old Aug 21, 2002 | 10:04 PM
Blown90hatcH's Avatar
Little off topic...but Jeff C, there is an easy way for getting the casing back together. IF you are stuck...IM me.
Old Aug 22, 2002 | 03:45 AM
keithv's Avatar
Default Re: Okay now what the hell is this chunk out of my tranny drain hole?!? HELP!! (Blown90hatcH)
just to clarify, the 17mm bolt is the fill hole, not the drain hole.
blown90hatch, could you let us all know this "secret"? i know i had a heck of a time trying to get the two halves back together this one time. all the times before that i had no problems whatsoever so it was baffling to me.
Old Aug 22, 2002 | 04:41 AM
JDM_DOHC_SiR's Avatar
New User
Yea two flat tip screw drivers
Old Aug 22, 2002 | 04:58 AM
keithv's Avatar
Default Re: Okay now what the hell is this chunk out of my tranny drain hole?!? HELP!! (JDM_DOHC_SiR)
i had a ring expander and that still didn't help me getting the two cases back together. i had to use LOTS of persuation to get the two halves back together.
Old Aug 22, 2002 | 05:32 AM
Jeff C's Avatar
that is how i was attempting it for the first hour and a half...but no luck
bought one of those after attempts with screw drivers...still no luck after another 30 min of frustration.
what kind of persuation...rubber mallet?
Old Aug 22, 2002 | 05:47 AM
keithv's Avatar
i used a dead blow hammer on it. took many whacks.
now that i think about it, pull the main and countershafts and place them in the tranny "cover". i would make sure it all fits into the cover with the snap ring in place. if it does, measure the part sticking out and see how much depth you have in the clutch housing portion of the case. this way you can make sure its not binding up b/c the mainshaft is sitting up too high.
Old Aug 22, 2002 | 02:24 PM
specie's Avatar
[QUOTE]I accidentally fill the oil using the hex one. If I open the 17mm nut next to the CV joint, everything should drain out to the right level, right? Thanks.
I took off the 17mm hole and about 4 quarts of oil drained out. Tranny shifts a lot smoother now. Thanks.
5thgencivic
Aug 15, 2003 01:29 PM
ams0465
Jun 13, 2003 10:07 AM
B_1_8_hatch
27
Aug 15, 2002 12:25 PM
