JDM GSR CIVIC
Old Jun 11, 2009 | 11:17 AM
SniperRCivic's Avatar
Icon2 JDM GSR CIVIC
right off the bat, IVE SEARCHED, i have a 98 civic with a 97 JDM GSR motor what my question is the teg motor is a lil heavier the the EX.. I need new shocks , so what i wanted to know is if i order the teg shocks will they fit... maybe my computer is special but again IVE SEARCHED..... thanks for any help
Old Jun 11, 2009 | 11:48 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
Default Re: JDM GSR CIVIC
why would you order teg shocks to put in a civic? if your worried about the weight of it get stiffer springs....there is no way the EX weighs more or just as much as a JDM GSR...the JDM GSR came with LSD correct? no way the EX is heavier. Its a single cam up against a dual cam.
in short - NO the teg shocks will not fit...use a good suspension setup for a civic and youll be fine.
Old Jun 11, 2009 | 12:50 PM
99fbpem1's Avatar
If you are worried about the front end dropping, get stiffer springs or coilovers. With coilovers you can adjust to the height desired.
Old Jun 11, 2009 | 02:00 PM
i see... i had a EX and now have the GSR motor.. and every time i hit a small bump it sounds like a pot hole , so i know that i need shocks and wanted to know if i should get teg shock... from what u are sayin there the same and its all in the spring... what rate should i get and should i get ones for a teg thanks again
94LS_allmota
Suspension & Brakes
Apr 3, 2005 11:17 PM
Integra4lyfe
Dec 19, 2003 02:30 PM
blkbeast
Dec 11, 2002 02:32 PM
