98 Prelude - Engine shut off while driving?!
Old Jun 11, 2009 | 10:17 AM
gio_vanni's Avatar
New User
Icon6 98 Prelude - Engine shut off while driving?!
I was driving the other night & my car unexpectedly shut off. It wouldn't start so I had to be towed home. Had plenty of electrical power & it seems the issue is fuel related.
Checked the fuel pump, still working & plenty of gas running through. Checked the spark plugs & replaced the fuel pressure regulator, and MAP sensor. Still will not start. Can't be fuel filter related because plenty of gas was running all the way up to the fuel pressure regulator when I disconnected the hose.
I ran a diagnostics check & came up w/ trouble codes P0108, P0401, P0420
Any thoughts?
Old Jun 11, 2009 | 11:13 AM
slow96lude's Avatar
Default Re: 98 Prelude - Engine shut off while driving?!
did you clear the codes and try starting it? most of those codes are emissions codes, being the cat and the egr valve
Old Jun 11, 2009 | 11:30 AM
gio_vanni's Avatar
New User
didn't try clearing the codes, but i didn't think the car's computer would actually prevent it from being started?
P0108 was an error w/ the MAP sensor, which i replaced.
P0401 & P0420 are problems I've had before, which were solved w/ new O2 sensors, however they never actually prevented the car from running.
i'm afraid that if i clear the codes, i will no longer be able to run a diagnostics check. being that if the car can't run, the computer will not be able to rescan itself
when i try to start, the engine turns and turns, but just doesn't seem to be getting gas?
thanks for the reply, this is very frustrating
Old Jun 11, 2009 | 12:04 PM
slow96lude's Avatar
your right usually the codes wont inhibit a car from running. did you check and make sure the injectors were firing while you we cranking the engine? I would try resetting the codes tho for the fact that you already know which ones its throwing and when you try starting it again they will probably come back on if they are not resolved
slow96lude's Avatar
by checked the spark plugs you mean you checked to make sure there was spark correct? was it a blue spark or orange?
Old Jun 11, 2009 | 12:10 PM
minime-dom's Avatar
i have had this happen to me before and it was my iac valve i put a new one on and it started right up
getzy3
19
Apr 19, 2023 03:23 PM
triple5soul8781
Aug 24, 2008 06:24 AM
dis_epix3
Aug 31, 2006 03:52 PM
qslim
Jul 21, 2006 10:09 AM
93b20z
Apr 10, 2005 07:54 AM
