brakes don't have enough pressure. please help!
Old Jun 11, 2009 | 07:34 AM
yoshizawa's Avatar
Default brakes don't have enough pressure. please help!
my name is josh. i'm a newbie 2 da forum and i seriously need some assistance. i bought a 91 integra gs 4 $1200 back in april from i guy that allegedly "raced" the car. i virtually got it for a steal, becuase it came with a r33 body kit (no bumper), stage 2 clutch (not sure what brand yet), short shifter (not sure what brand), adjustable coilovers (tokico), 17 in. enkei rims, catback exhaust (not sure what brand), and a recent motor swap. (still a B18A1). the only thing truly wrong with it was that the brakes didn't have enough pressure to stop the car on a dime. so far i have changed the brake booster (its a junkyard booster from a 4 dr 91 teg), i've replaced the rear driver side caliper (due to it being frozen), put slotted rotors with ceramic pads on all 4 sides, (summit racing brand), and have bled the lines several times to make sure that there's no air trapped in them. even after this, it still seems to be no pressure building when i pump the pedal. the calipers are functioning, but i have 2 press the brake all the down 2 get them 2 even begin 2 slow the car down. please give any feedback that you may have on the matter. thanks in advance.
Old Jun 11, 2009 | 07:38 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: brakes don't have enough pressure. please help!
Possibly a bad master cylinder.
Old Jun 11, 2009 | 07:43 AM
yoshizawa's Avatar
how will i be able to tell if its bad?
Old Jun 11, 2009 | 09:26 AM
Dogginator's Avatar
Daisy... Daisy...
Does the pedal sink to the floor? Can you ever produce pressure when pumping quickly?
Old Jun 11, 2009 | 01:18 PM
MikendablkDB8's Avatar
could be a leaking brake booster
Old Jun 11, 2009 | 02:11 PM
Dogginator's Avatar
Daisy... Daisy...
That would result in a hard pedal, not a low pedal.
Old Jun 11, 2009 | 02:28 PM
trifenix's Avatar
possible brake booster leaking....go start the car, and get your head next to the brake pedal and press it with your hand...do you hear a whooshing sound or the engine revving? if so its leaking.
Old Jun 11, 2009 | 04:56 PM
jdm_bones's Avatar
Check all your brake lines, and caliper bleeder screws, can also be a bad valve that goes from the booster to the manifold, or a bad prop valve...check everything twice...Also there is a gasket that goes between the booster and the master cylinder that goes bad, check that as well.
Old Jun 11, 2009 | 09:03 PM
yoshizawa's Avatar
i put two gaskets between the master cylinder & the booster. when i press the pedal, it feels like its functioning normally, but for some odd reason there seems to be no pressure building when i pump the brakes. the pedal doesn't get harder. its not quite a spongy feeling, just more so.... weak.
Old Jun 11, 2009 | 09:15 PM
yoshizawa's Avatar
the only things i haven't changed are the prop valve, the valve that comes from the manifold, & the master cylinder. all of the bleeding screws are good and tight.
Old Jun 11, 2009 | 09:17 PM
dohcvtak's Avatar
try replacing the brake master cylinder make sure to bench bleed
Old Jun 11, 2009 | 09:26 PM
yoshizawa's Avatar
i did the bench bleed when i put the old master cylinder back on. i may do it again, because i'm not too sure i did it rite after reading a detailed description of it.
Old Jun 16, 2009 | 06:19 PM
zehn's Avatar
It's prolly your master cylinder. Same thing happened to me last week and I replaced it. Problem solved.
Old Jun 16, 2009 | 08:33 PM
screaminscot's Avatar
There should be only one gasket between the master cylinder and brake booster. That said I believe you have a leaky master cylinder.
Old Jun 17, 2009 | 06:57 AM
yoshizawa's Avatar
now that i think back on it, it may be the master cylinder, because when i was bench bleeding it the brake fluid only came out of the front valve when i fully pressed the piston. it would occasionally shoot from both, but when it did the stream was very weak for the valve in the back. after i let it sit for several minutes, a solid stream shot from both valves after a full press. can this be an indication that its possibly malfunctioning?
Old Jun 17, 2009 | 09:58 AM
WDG_729_ITR's Avatar
Well...have you checked the fluid?...sometimes people go way into depth with things thinking there is something a lot worse wrong when it's just a simple problem with a simple solution.
Old Jun 17, 2009 | 07:09 PM
yoshizawa's Avatar
the fluid is fresh.
Old Jun 18, 2009 | 09:02 AM
Oh ok, well then yeah...most likely the master cylinder.
Old Jun 18, 2009 | 09:29 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Replace MC, and only use one gasket/seal. I used to have a problem of the pedal sinking to the floor while sitting at a stoplight. New MC fixed that. Then later I had a problem with vacuum in the booster leaking out after shutting the car off. New MC seal fixed that.
Also please type "to" instead of 2 everywhere, it's kind of annoying to read.
Old Jun 26, 2009 | 07:21 PM
yoshizawa's Avatar
gotcha. i'm currently saving up in order to replace the master cylinder and possibly the brake booster as well as a set. once i change them, i will notify you all. thanks for the help guys.
Old Jun 26, 2009 | 07:29 PM
dntnedvtec's Avatar
Look in the area of your barke pedal, if its wet, its bad. I had to replace the clutch mater cylider. It was all wet near the clutch pedal.
But I could be wrong...
Old Jun 26, 2009 | 07:38 PM
yoshizawa's Avatar
i actually checked that first, because a friend had the same problem that you had. when i crunk the car up yesterday i had a buddy of mine take the MC cap off and i pressed the pedal down repeatedly. he told me that the fluid in the MC didn't rise or bubble at all as if there was nothing flowing from it, but when i bled the brakes before it seemed to be functioning correctly, because it pumped fluid whenever the brakes were pressed down.
Old Jul 6, 2009 | 07:52 AM
yoshizawa's Avatar
I'm changing the master cylinder today (finally had money left over after paying bills). I'll give a report afterwards.
Old Jul 9, 2009 | 09:43 AM
yoshizawa's Avatar
I changed the master cylinder and nothing changed. there still seems to be no pressure building up in the systems what so ever.
Old Jul 22, 2009 | 12:06 PM
yoshizawa's Avatar
found the problem. turns out that the valve in between the booster and the intake manifold was bad. i got a few of them from the junkyard and tested them until i found one that worked. thanks for the help and feedback as to what might have been the problem.
Tegraracer90
Dec 2, 2010 01:47 AM
cityofcaterpillars
Jan 31, 2010 03:06 PM
denniscoles
Mar 13, 2008 04:16 AM
SumOne
Oct 28, 2006 01:52 PM
