Another overheating problem
Old Jun 11, 2009 | 06:07 AM
jdmcivic1's Avatar
Default Another overheating problem
The car is a 96 Civic Dx. The temperature gauge goes above normal right when you start the car. Then when driving it would go all the way to Hot then back to the middle. I replace the radiator and coolant/ temperature sensors. My upper and lower hoses get hot. So I doubt it's the thermostat staying open or close. What else could be the problem? Any suggests? Thanks!
Old Jun 11, 2009 | 06:10 AM
97twodoor's Avatar
Default Re: Another overheating problem
Sounds like a head gasket to me. Any bubbles coming out of the top of the rad with the cap off?
Old Jun 11, 2009 | 07:16 AM
Jimster480's Avatar
its headgasket. This is what would ahppen on my car before the headgasket was replaced. It would also burn through coolant. Its not a totlaly bad HG but a leaking one, which is why it doesnt happen after the first time (usually) becase it seems to seal itself back after the engine hits the temp. Pull the head and replace the gasket.
Old Jun 11, 2009 | 10:34 AM
jdmcivic1's Avatar
dam. i was hoping it wasn't the headgasket. might has well swap a better engine than spent the money fixing it.
Old Jun 11, 2009 | 10:59 AM
slow96lude's Avatar
an easy way to figure it out would be to just take out the thermostat. and very effective thats the problem. only takes a few minutes
Old Jun 11, 2009 | 12:01 PM
EL Vap133's Avatar
If you plan on upgrading the engine then might as well do it now. If not, see if it is worth fixing.
I had a slow leak on my headgasket and the car would overheat due to a faulty wire for the fan. Had it checked out, had the gasket replaced and car runs better than ever for the last 1.5 years.
Old Jun 11, 2009 | 12:18 PM
Jimster480's Avatar
dude wtf. A bad headgasket is no reason to put a new motor in the car. its a ****ing hour and a half and $40 to fix a headgasket. If you are leet like me you can get some friends to come over and hold the head up. I just un tq'd it and had my friends hold the head while i replaced the gasket. Then we set it back in place and torqued it again.
Old Jun 11, 2009 | 12:33 PM
EGR95's Avatar
true....
Old Jun 11, 2009 | 01:39 PM
Sr420Det's Avatar
you should of at least cleaned the surface.
Old Jun 12, 2009 | 10:36 AM
jdmcivic1's Avatar
it's only a DX with 170,000. I would have to say it's on it's way out and yes it's worth replacing with you spent the last month fixing endless things on it while you could be spenting that money and time on a more powerful DOHC series.
Old Jun 12, 2009 | 02:29 PM
Jimster480's Avatar
ya get ready to spend 3k+ for 60-70 HP. DOHC motors arent worth it unless your trying to go all motor. Built D's are cheaper and a way better value if u wanna go boost. Unless your trying to make like 450+WHP. Its easier to build a D. Mine made 270WHP on 13.5PSI from a Ebay t3/t04e.
02CivicXer
Honda Civic (2001 - 2005)
Sep 18, 2007 06:37 PM
iperez
Jan 5, 2004 08:52 AM
flex97itr
Jul 4, 2002 11:04 AM
