Need help diagnosing ticking under medium/hard acceleration?
Old Jun 11, 2009 | 05:51 AM
-iLLuZioN-B18C1's Avatar
Default Need help diagnosing ticking under medium/hard acceleration?
Background info:
1993 civic dx with 162000 miles. Stock everything.
If I apply medium to hard pressure on the gas, I hear a ticking noise. It sounds like it is coming from the engine bay. If I barely press the gas (ex. Cruising on the highway) or idle at a stop, I do not hear any ticking.
Old Jun 11, 2009 | 06:43 AM
Jimster480's Avatar
Default Re: Need help diagnosing ticking under medium/hard acceleration?
CV joints. You need a new boot or a whole new joint. Jack it up and see if there is greese comming from one of the joints. If not then its a little harder to figure out which one it is. Go for a drive and make a hard/medium turn and give it gas when you turn, if it clicks its that side, otherwise turn around and turn the other way and see. Which ever side it clicks/noise is comming from is the bad CV Joint.
Old Jun 11, 2009 | 07:59 AM
civic_driver's Avatar
Sounds like your motor is pinging. Is the ignition timing too advanced? Make sure it's set at 16 BTDC for a stock motor.
Old Jun 11, 2009 | 01:50 PM
so if i make a left turn and makes a noise its the left side?
Old Jun 11, 2009 | 04:44 PM
Jimster480's Avatar
yes normally.
Old Jun 11, 2009 | 05:18 PM
phatmitz's Avatar
I agree with civic driver, sounds like timing. My 96 ek was making the same noise so I checked timing and found out that the timing was at about 20-25 btdc. Found out the timing belt needed replacement. You should get it checked out soon.
Old Jun 11, 2009 | 06:36 PM
was yours happening constantly or only under med/hard acceleration?
and about the cv being the problem, now that i think about it I do think the noise is much louder during turning while accelerating. cruising is completely silent on the other hand. which makes me think its not the timing.
Old Jun 11, 2009 | 07:49 PM
phatmitz's Avatar
My problem was happening only under med to hard acceleration. Didn't matter what gear I was in either.
j-wow
Honda Civic (2006 - 2015)
Nov 15, 2015 07:08 AM
my94d16y8coupe
Oct 18, 2011 03:28 AM
KEMIS
11
Jan 12, 2011 10:00 PM
LS94tegra
Jan 2, 2008 09:48 AM
Miller Time
Jun 15, 2003 02:19 PM
