Car Shakes at Launch
Old Jun 11, 2009 | 02:09 AM
bandit080000's Avatar
Default Car Shakes at Launch
Hey everyone,
So a few months ago, my car started shaking pretty mildly when launching from first gear. Now, the car shakes fairly heavily when launching from first gear.....While driving, I feel no signs of clutch slippage, but I was wondering if I could attribute this to the throwout bearing? Would buying a clutch replacement kit such as:
http://www.autozone.com/autozone/cat...054&questions=[]
solve the problem? I should also mention that I have the notorious third gear grind. Otherwise, would a Z6 transmission bolt up to my Y7 mini-me? Either option would be fairly easy, since the motor is currently out on the rack after a crank pulley mishap.
Or could it be my motor mounts? The motor is mildly built...stage 2 cam, and p29 pistons, I/H and a chipped ECU.
Thanks, and as always, I appreciate any advice anyone can give me!
Old Jun 11, 2009 | 04:15 AM
cpl rampage's Avatar
Default Re: Car Shakes at Launch
chances are it is a combo of poor motor mounts and poor suspension, creating wheel hop. it could also be your trans going out too, maybe the counter shaft or input shaft bearings?
At a minimum get the polyurethane motor mount inserts while you have the engine out, see how that helps.
If its still a problem, check your front suspension bushings for wear, and get a stiffer suspension... or a traction bar, but i doubt you need that with a mild na build like that.
And yes a z6 trans will bolt right up, you will want to do that anyways because it has better gearing.
Old Jun 11, 2009 | 06:44 AM
F20B-CX's Avatar
It's clutch chatter. Replace the disc.
Old Jun 11, 2009 | 06:50 AM
Jimster480's Avatar
put a z6 trans in if your going to take out the clutch. Its gears are shorter and better for your mild build.
Old Jun 11, 2009 | 11:43 AM
etank82's Avatar
When my motor mounts were shot, it would shake pretty bad, but only at idle...
Old Jun 11, 2009 | 12:11 PM
I looked up information about both, but I'm not sure how to interpret it. Can someone please explain this to me?
D16Y7 2000 Civic Coupe / Sedan
1st gear Ratio 3.25
2nd gear Ratio 1.782
3rd gear Ratio 1.172
4th gear Ratio 0.909
5th gear Ratio 0.702
Final Drive Ratio 4.058
D16Z6 1992 - 1995 Civic Coupe
1st gear Ratio 3.25
2nd gear Ratio 1.909
3rd gear Ratio 1.125
5th gear Ratio 0.75
Final Drive Ratio 4.25
Thanks!
Old Jun 11, 2009 | 12:14 PM
Jimster480's Avatar
the final drive shortens all of the gears because it is a higher number and has less teeth.
ED9
13
Nov 26, 2010 06:29 PM
tech410
10
Jul 15, 2010 05:30 AM
1hgej1
Mar 30, 2009 09:55 AM
FuNkDrSpOt
15
Oct 15, 2007 03:03 AM
beany
Aug 23, 2007 02:55 AM
