help w/primary oxygen sensor and speed sensor is???
ok so i got an eg wit a b20 swap and i checked my codes and it says i need my primary oxygen sensor and speed sensor......but the thing is i dont know where they are located on the engine if someone could help out with some pics showing me where they are located so i can replace and enjoy my car........cool thanks
for the o2, follow the header down and back until you run into the first oxygen sensor..
for the vss, its located on top of the tranny under the distributor almost.. its like the only sensor on there.
"build it, don't buy it.."
vss, look where the axles go into the transmission, its one 10mm bolt. 3 wire sensor, its black, and easy to get to, o2s, what the other guy said, follow the exhaust manifold back, and it should be a 4 wire sensor.
