Just need some clarification
Old Jun 10, 2009 | 09:35 PM
Fine_EF9's Avatar
Default Just need some clarification
first was dpfi doesnt have a fitv correct?
second, would a bad tps cause a irregular idle bouncing,
third is every once in a while my cel comes on and the codes are 1, 7, 14,
i know what the codes are, (o2 sensor, tps sensor, iacv) would the tps cause this all, and when i turn the car off then back on the cel disappears
Old Jun 10, 2009 | 10:04 PM
89s1's Avatar
Default Re: Just need some clarification
1. Correct
2. It's usually something else to be honest. bad iacv, or air in the cooling system, etc.
3. try a new tps, they're easily had at the junkyard. just remember the dx tps operates in reverse of most other honda tps's. If you replace it with a tps off a different car with mpfi you'll need to swap the outside two wires on the tps plug of the engine harness.
Old Jun 11, 2009 | 10:50 AM
Fine_EF9's Avatar
ok cool thanks man. i have also read up that you have to calibrate the tps since there calibrated before hand at the factory. how would i go about doing that?
Old Jun 11, 2009 | 11:38 AM
89s1's Avatar
its been covered, it needs to output certain voltages, if you do a search you'll find the correct voltage amounts to calibrate it to. I don't know them off the top of my head.
Jakester9500
Nov 19, 2008 07:10 AM
jfruauff
10
May 3, 2008 11:41 PM
MelloYelloCRX
May 5, 2007 06:10 PM
iamhollywood[BRS]
Sep 21, 2006 07:25 PM
ofthedove
Jun 1, 2004 01:04 AM
