Idling Problems
Old Aug 20, 2002 | 11:47 AM
jimw2112's Avatar
Default Idling Problems
I recently remove the evaporator on my 1991 Civc hatchback (1.5 Dual point fuel injection) to replace the expansion valve. After I reinstalled the evaporator, my engine idles fine from a cold start, after about 3 minutes it starts a hunting or surging idle. I've read many of the posts about the possible causes of the surging idle. Can changing the evaporator cause the idle to surge?? I've changed the spark plugs, distributor, rotor, in process of changing all the vacuum lines, sprayed carb cleaner, etc. I had to move the EVAP cannister out of the way to get the coolant hoses off the evaporator. Could this cause it.
Thanks
DAb18c
Jul 9, 2011 12:36 PM
sloweh3
47
Jan 2, 2009 07:45 AM
toastyfishands
Jun 12, 2007 11:29 AM
93SSPHatch
Aug 2, 2002 08:06 PM
jpelle
Mar 15, 2002 12:46 PM
