Here's the plan...
Alright, I wanted to get a B16, most people say go for a B18 instead because it has more torque, but I love vtec and I love revving high, so here's what I am planning on doing. I will first get a B16 and drive it stock (more or less) for some time while I save up some more. Then I'll get a B20 block and swap the B16 block for the B20 block. I will then again drive this setup for a while, save up some more again and put a turbo the whole.
What do you guys think? In 2 years or so I should have a very good setup....
why not just drop the b20 in first? It will be a little slower than a b16, but then later you would just have to put the b16 head on instead of switching out the blocks. A b20 with an integra intake manifold and simple bolt ons wouldnt exactly be a slouch by any means. Other than that sounds like a good setup, although b20 turbo would be nice too because of its lower compression.
in my opinion i will slap that B20 first........ u will have a nice torquy engine but not as high reved....... then just get a b16 head wich its going to be easier to find than a B20 by itself..... then u can put a GSR intake manifold and u got a nice fu%^&* engine!
Well, the problem with that is that I need to have the car rewired for the B20 and the rewire it again for when I put on the SIR head. Plus, I can get a good deal on a complete B16 swap, everything from axles to tranny to computer. Then it should be easy to get a B20 block and swap it in. I can't just put a B16 head on the B20 anyways. I need to change the pistons, reprogram the ecu and a bunch of other stuff. Plus, I'd rather get a B16 for a while than a B20. I like to rev my engines high!
I might just end up getting the B16 and turbo it instead of putting the B20 block, or I could do both, but I'm not sure of the order...
adonis2oo2
30
Jan 4, 2007 10:31 PM
