Dyno and gearing question?
Went to the dyno in May (A mustang dyno) and made 202whp and 130ft-lbs
Went to the same dyno yesterday and made 193whp and 127ft-lbs???
In May, 94 octane - 25ignition at WOT - 4th gear pull with 1.108:1 and 4.928:1 FD
Yesterday, 100 octane - 28ignition at WOT - 4th gear pull with 1.034:1 and 4.928:1 FD
When I overlayed the 2 graphs, I was 5-7whp less across the board from 3000-9000rpm?
Is it the longer gear that I used yesterday that did this....motor 250-255 comp across the board which was the same as in May?
Steve
